GS460 1U V8 Oil Use
Old 08-12-18, 04:48 PM
HaryGahtoe
HaryGahtoe's Avatar
Default GS460 1U V8 Oil Use
Interested in other owners chiming in here.
Bought Mobil1 0-20W EP Synthetic oil and a Toyota filter.
What are you 460 (1U) owners using?
Thanks for any replies
Hary
Old 08-13-18, 07:12 AM
TRD_Power
TRD_Power's Avatar
I'm lazy and take it to the stealership for the oil changes now, so I believe Castrol is what's used. Mobil 1 and Liqui Moly are my personal go-to's when I used to change it myself. All synthetic, of course.
Old 08-13-18, 08:55 AM
tghw
tghw's Avatar
I would never run oil that thin in my GS.
Old 08-13-18, 09:53 PM
HaryGahtoe
HaryGahtoe's Avatar
And quite possibly you shouldn’t
Also the reason I specifically posted GS460. ^
GS460 are listed as factory recommended 0-20W.
Thats why I went with Mobil 1 EP synthetic 0-20W
Old 08-13-18, 10:03 PM
tghw
tghw's Avatar
Even if I had a 460 I wouldn't run oil that thin. I don't care what the manufacturers recommend. The manufacturer's mainly spec it to improve fuel mileage. The viscosity of that stuff is like water.
I'm not suggesting what you should do, that's just my personal opinion.
Old 08-14-18, 06:10 AM
TRD_Power
TRD_Power's Avatar
I've always used 5w-20 in my 460, and that's what I now have the dealership use. Never had any issues, and as tghw said, it's simply to improve fuel economy, which I personally couldn't care less about when it comes to protecting my engine long term. I'm sure 0w-20 is just fine, but my vote goes to 5w-20.
Old 08-14-18, 08:57 AM
HaryGahtoe
HaryGahtoe's Avatar
Absolutely. Your car, your choice.
Viscosity ratings have changed in conjunction with engine technology. Manufacturers have improved on reducing bearing drag while increasing power. Oil like 0-20 deliver that tighter tolerance level previous engine design weren’t needed.
A major oil demand has to to with VVT ie. Oil viscosity is critical to a sophisticated electronic valve control. That is why it really is important to use what Toyota specifies.
I’m also not telling anyone what to use, just prefer to stay with manufacturers recommendation on this one considering such sophisticated equipment
https://en.m.wikipedia.org/wiki/VVT-i
Old 08-14-18, 09:01 AM
HaryGahtoe
HaryGahtoe's Avatar
What does a dealer charge these days for a filter and oil change?
Old 08-15-18, 06:11 PM
Fausty
Fausty's Avatar
I’m using penzoil platinum full synthetic 00-w20 and a Toyota filter.
Old 08-15-18, 10:21 PM
Lukas99GS
Lukas99GS's Avatar
my dealership always writes me up at $50 but then always come back and end up charging me $80 because I have a 460 and they always put me in as a 350 because apparently I'm one of two people who has ever brought a 460 to my dealer
Old 08-16-18, 12:33 PM
HaryGahtoe
HaryGahtoe's Avatar
You know even if they charge you $80 that’s a good deal
l paid $60 for Mobil1 EP oil and filter so that’s actually quite good
Good Luck
Hary
Old 08-18-18, 08:01 AM
KevGS460ML
KevGS460ML's Avatar
I believe the recommended viscosity is 5W-20 not 0. Anyway, the first number is for cold temp, and here in TX it's not that cold even in the winter, so 5 is sufficient. I have been using Mobil 1 full synthetic on mine since new, and it has 175k now still running like new. I buy OEM oil filters from some dealer seller on Amazon for $4.50 each, and the washers from fleebay.
Old 08-18-18, 04:34 PM
HaryGahtoe
HaryGahtoe's Avatar
Kev, I believe in individualism, the reason why car calls for 0-20 W oil is all Toyota.
Engineering has more to do with recommendations than temperatures.
460’s use oil pressure to adjust valve timing. So changing the oil W can be hurting performance and not merely for surface lubricant qualities
The owners manual truly recommends 0-20w.
Choosing oil outside of recommendations isn’t unheard of but it will effect valve timing
Good Luck
Hary
jrk1956
06-04-19 05:32 AM
jud149
11-27-18 07:15 PM
jdanielca
10-06-18 08:13 PM
FASTEDDY
Maintenance
03-20-18 07:36 PM
Zeal3
04-19-09 04:07 PM
Quick Reply: GS460 1U V8 Oil Use
