2013 GS coolant change?
Attached procedure from my bootleg manual. ($60 on ebay...and it's proven to be pretty useful, not quite as good as the old factory manuals, but good enough.)
praetor (06-20-18)
Thanks for the manual.. I should do mine also.
you should leave the expansion bottle open and let it heat it up to temperature. It should self bleed the air... Then fill to level again. Havent done my GS but almost all newer generation cars are like that
jonathancl (06-21-18)
Yeah it's not brakes. It's an open system and the air will self bleed. You just need to run it to operating temp and top off coolant as needed.
