P0770 and P0750 Error Code
I have a 2002 LS430. I have researched the codes and have found that P0770 is shift solenoid E and P0750 is solenoid A. What I can't find out is what the part #'s are when you try to buy them. Not sure what to order. I also can't find a good photo of where these are located on the transmission. Any help would be great.
Start here- https://www.lexussouthatlantaparts.c...category=21756
It looks like P0750 refers to Solenoid Valve No 1, 2 and 3 and P0770 refers to the Lock Up Solenoid (SLU) 35280
GoingBroke (04-25-18)
Will the springs come out when you pull the solenoid out? Not sure how this looks yet once I take the pan off. Not sure if I have to pull the valve body off to get to the solenoid. I can't find a video of anyone doing this jo
Hello you should troubleshoot systematical and lookup how to back test the solenoid to determine if in fact is is bad. I was in a situation not to long ago where my computer was throwing errors at me and I was replacing things just to get another error after.
