P0770 and P0750 Error Code
Old Apr 24, 2018 | 03:55 PM
GoingBroke's Avatar
GoingBroke
Default P0770 and P0750 Error Code
I have a 2002 LS430. I have researched the codes and have found that P0770 is shift solenoid E and P0750 is solenoid A. What I can't find out is what the part #'s are when you try to buy them. Not sure what to order. I also can't find a good photo of where these are located on the transmission. Any help would be great.
Old Apr 24, 2018 | 04:54 PM
05ls430518's Avatar
05ls430518
I would just buy a used transmission at this point it would be cheaper.
Old Apr 24, 2018 | 05:15 PM
bradland's Avatar
bradland
Start here- https://www.lexussouthatlantaparts.c...category=21756
It looks like P0750 refers to Solenoid Valve No 1, 2 and 3 and P0770 refers to the Lock Up Solenoid (SLU) 35280
Old Apr 24, 2018 | 05:26 PM
05ls430518's Avatar
05ls430518
Side note if you decide to take it apart be carefull because springs will go flying across the room never to be seen again.
Old Apr 25, 2018 | 07:24 AM
GoingBroke's Avatar
GoingBroke
Will the springs come out when you pull the solenoid out? Not sure how this looks yet once I take the pan off. Not sure if I have to pull the valve body off to get to the solenoid. I can't find a video of anyone doing this jo
Old Apr 25, 2018 | 11:25 AM
bradland's Avatar
bradland
This is from a 2000 LS400 but it's the same A650E trans in your 2002.
File Type: pdf
Old Apr 25, 2018 | 07:24 PM
05ls430518's Avatar
05ls430518
Yes they will they are spring loaded just be very careful when doing it and do it in a empty room so if they go flying you can find them.
Old Jan 6, 2019 | 11:37 AM
khalid3230's Avatar
khalid3230
hii, me 2 ive got an error code P0756 it refers to Shift solenoid valve No. 2 where it could be!!
Old Jan 6, 2019 | 12:11 PM
duster562's Avatar
duster562
Hello you should troubleshoot systematical and lookup how to back test the solenoid to determine if in fact is is bad. I was in a situation not to long ago where my computer was throwing errors at me and I was replacing things just to get another error after.
donmcc
Jul 9, 2024 06:23 AM
dusky2001
Nov 13, 2023 12:08 PM
dusky2001
Jan 30, 2017 08:16 AM
Lexluuuger
Jan 23, 2015 08:46 AM
