Cheap fix for black spotted rear view mirror?
Old 01-23-18, 08:46 AM
chucktaylu
chucktaylu's Avatar
Default Cheap fix for black spotted rear view mirror?
I just purchased a 2006 is250 and there are black lines all over the rear view mirror. After some research, this seams to be a common problem with Lexus. Is there a cheap fix for this? The replacement part (8781053160) costs $900+. Is there a cheaper compatible replacement I could buy? Maybe like a Toyota mirror that would fit?
Old 01-23-18, 09:01 AM
XSV
XSV's Avatar
yes it is common. buy a used oem one off ebay, that's what I did.
Old 01-23-18, 09:06 AM
gompka
gompka's Avatar
http://www.radar-mirror.com/Mirror_Repair.html you can get the glass replaced for about $100
MadMack58 (02-14-21)
Old 01-23-18, 09:12 AM
DMV350
DMV350's Avatar
Old 01-23-18, 09:18 AM
chucktaylu
chucktaylu's Avatar
Are mirrors from other years / models compatible?
Old 01-23-18, 12:20 PM
Aspect
Aspect's Avatar
anyone have a DIY of the cleaning procedure or is it not possible?
Old 01-23-18, 12:45 PM
2013FSport
2013FSport's Avatar
Received 1,484 Likes on 1,238 Posts
Not possible as I know it as the flaw is on the back of the glass. The reflective coating has delaminated.
Look on fleabay and don't exclude the GS chassis and you may as well get a compass mirror too. Make sure the seller has a return policy if it is flawed.
Old 01-23-18, 12:50 PM
chucktaylu
chucktaylu's Avatar
Thanks. I saw this option as well. However, there are many used OEM mirrors on ebay for under $50. Im just not sure which ones are compatible with the 2is.
Old 01-23-18, 01:08 PM
Aspect
Aspect's Avatar
I found this oem/JDM Lexus mirror as well, except it's not cheap http://www.nigel-jdmparts.com/index....id=440&page=17 not sure if it'll work though
Old 01-23-18, 02:17 PM
Zmon
Zmon's Avatar
Careful with some mirrors. If you buy a mirror off one of the various Lexus models, you need to check the pin layout. I believe our older IS's (at least 06-08ish) use the 5 pin layout (though possibly those that came with the luxury package may have a 10 pin layout due to the auto dimming side mirrors). If you buy a mirror off a newer IS/GS/etc, you'll need to buy a harness for it. I replaced my mirror last year with one off a 2010 GS since I wanted to keep the compass (really liked how the GS has the compass behind the glass versus a black cutout that the later 2IS's had), and preferred the new style of mirror versus the one on our older IS's, so I had to grab a premade 10 pin harness off of eBay for $20. Otherwise, find a mirror from your year that isn't damaged.
Easiest thing to do is just go the repair route and ship it to the guys gompka linked to though, may be the cheapest/least hassle anyways, and you'll know its repaired versus one from a similar year IS that may or may not be damaged.
Old 01-23-18, 06:27 PM
belac
belac's Avatar
Not everyone's cup of tea, but I just clipped on a $20 Broadway mirror. It covers up the spots, gives me more rear visibility and I like the look.
Can't tell what direction Im going, but that's not the end of the world.
One of these:
Old 01-23-18, 08:57 PM
DMV350
DMV350's Avatar
Old 01-23-18, 09:23 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
Gentex supplies mirrors to Lexus. You may want to look here:
http://www.autoanything.com/mirrors/...13A2548A1.aspx
Lou
Old 01-24-18, 07:52 AM
XSV
XSV's Avatar
Not sure, read the description carefully before you purchase. Make sure it's compatible with your year and make. Make sure you also check if it has compass or not (if you want compass). I bought the exact same mirror that was in my car. I then sold the old one on eBay.
One of these:
I went that route for a while, but my mirror kept slipping off the OEM mirror. Eventually got fed up with it and replaced the OEM mirror with anonother OEM one.
Old 02-11-21, 09:12 PM
CowBoE
CowBoE's Avatar
I didn't want to spend $1500 on a new OEM mirror, and I wanted to keep the cool features like
home-link garage door opener, compass, and auto-dimming.
So I sent it out for repair for $120.
The following 2 users liked this post by CowBoE:
MadMack58 (02-14-21), mandyfig (02-14-21)
Gator73082
01-27-20 07:05 AM
Ironman50
05-06-19 08:31 PM
IS2006
09-02-14 05:27 PM
VinayRaju
07-22-14 01:34 PM
rayy
07-17-08 04:46 PM
Quick Reply: Cheap fix for black spotted rear view mirror?
