Steering Wheel telescopic adjustment
Is there a setting i can turn off, so the steering wheel won't extend and retract every time I turn on and off the car? i can't find it in the vehicle settings.
thanks.
Joe
thanks.
Joe
I do not believe you can effect the steering wheel separate from the seat retraction. The above is for both Seat and Steering Wheel.
I suspect if the normal driving position had the steering wheel fully retracted (toward the dash) it would just stay fully retracted and not move when the seat goes back... Most people have an issue with the driver's seat going back, because it cramps leg room for the back seat occupant...as-if it's not already cramped for leg room when the front seats are moved back.
I have mine set to retract the wheel but not the seat. Love the wheel retraction, but hated the seat moving.
I do not believe there is a way to turn off the steering wheel portion.
To stop the seat from moving, I did as described above and set the easy access system to OFF.
You can do it through Techstream. I had the steering retraction disabled at some point as I was worried about the wear on the telescopic adjustment mechanism over time. But eventually I reverted it back because being 6' tall, I found getting out of the vehicle was just so much easier with the steering wheel retraction on. One day it'll probably cost me dearly when it decides to go.
jpsartin
RX - 3rd Gen (2010-2015)
06-01-16 08:02 PM
MikeZero
02-03-15 04:33 PM
