lexus noob
lexus noob
hi guys, im picking up a 2006 IS AWD tomorrow. this is my first lexus. Its got 141k. could anyone refer me to information you feel i should look at? anything outside of the norm i should be aware of? like, timing belts or the crazy maintenance schedules for BMW and Mercedes? this will be my car for at least a few years, as long as i dont crash it
thanks, Bryce
thanks, Bryce
You should be in pretty good shape with it, as long as the previous owners did regular maintenance. Check it's history for that and if it's been in any accidents. A clean, non-modded, original car is best.
As far as the "as long as I don't crash it," there's no reason to go down that road. Practice paying attention at all times, do not drive with a phone in arm's reach, do not eat or drink while driving, and don't speed. Paying attention at all times is always #1, I can't stress that enough. You should always be scanning far ahead, knowing who's next to you, and who's behind you. Respect yourself, respect others around you, and you will last long. Good luck with the IS!
bryceis250 (12-19-17)
I purchased a 2006 LS430 Oct. 2016 with 81k. Probably no surprise no problems in 19k miles. My advice would be to identify a Japanese indie near you, who installs customers' parts. This will reduce what a dealer charges by at least 50%. Also, I find with these cars there is an awful lot you can DIY, if you're into that...good luck.
Also, you'll see tons of OE Toyota/Lexus parts on eBay, new (in sealed bags), for much less than list, sometimes 50%+ off. As it was explained to me, the reason is the US Distributor has been cut out of the picture. If they're not, then 31% off list is the most I've seen....
2010 IS 250 with 95K miles purchased for 14K out the door. Still amking payments but i have not had this for almost a year. No problems at all. Tires are expensive as they are different sizes. Alot of forum post show this. Let's see here the carbon build up issue takes the lead. Sometimes in drive or reverse the RPM will jump and you can feel it in your seat like the Engine is coughing. No one around me does walnut blasting for a lexus. The dealership can give you a Top header clean and use some product which you will notice and feel how smooth it drives after. The car is dependable no matter what they say about it. Have not done any water pump replacement or brakes. Just oil changes which 3 of them were free. This is my first Lexus and I have had a handful of other cars. I recommend it but just know that the lower the year the car does begin to show it's age. Then the repairs can be a bit costly compared to Economy cars. Also if you still new to driving or student learner, get something that you can "CRASH" so you dont break the bank. Lexus owners pride them self on paint Quality so any chipping of paint or rims is like a Big No No. No 1 here is gonna have your back if you crash a nice car like that. Once you pick up the car as you stated, you should come back here and post about it. Anytime you buy a car and take it home, thats when you notice more things then you did in the parknig lot of the place that sold it to you. other than that good value for 2006 with 141k. How much did you pay just curious?
the free car fax knock off i read online said only the airbag recall from last year was undone. I dont know if this was the full information, as it was the first time i found it a free carfax.
what are your thoughts?
has the water pump issue been resolved in aftermarket pump or is it something else?
what does the tire wear come from, alignment? rear brake caliper aftermarket part resolve issue? are there TSB on these issues?
thanks man!
Also, the dip**** that i bought it from told me it runs synthetic and that he put synthetic oil in it. I pull a service record form 2015 of a previous owner and it was changed with conventional oil! what do I do? i heard you dont run synthetic after conventional .
its giving me a problem starting too. out dong errands. ill have to hit the bottom twice. it spit a little. its not good because its happening too frequently
thank you ! i will have this all checked out. as far as carbon build up, I found this article here: https://www.torquenews.com/1083/lexu...-you-need-know.
thanks man!
thanks man!
the tire wear comes from toe deflection under thrust loads, primarily braking, RR Racing sells the USRS and FIGS sells their super pro bushings that is a simple install, but will sacrifice a little ride comfort given the more rigid bushing
the rear caliper issue is due to the design of the glide pin design, usually replacing them with a remanufactured caliper should do the trick but it sort of depends on your luck, some members have had to replace them multiple times - an aftermarket BBK setup would resolve the issue since it changes the entire caliper design but $$$, IS350 rear calipers share the same problem since they are just slightly larger versions with the same design
make sure to get the transmission fluid changed, some people never change the fluid because they claim lifetime and end up having to replace solenoids or entire transmissions because of it
walkagain
ES - 5th Gen (2007-2012)
13
08-01-06 10:50 AM
