My interior lights switch from night to day ramdomly, whats the fix?
Old 12-11-17, 08:04 PM
Mishka430
Mishka430's Avatar
Default My interior lights switch from night to day ramdomly, whats the fix?
So i just noticed the interior lights (radio, suspension controls, gps dimmer, ect..) go from on to off randomly while driving at night. Its really aggravating because the gsp suddenly gets very bright and everything else (the gauges stay normal) goes black. Also, I'm not sure if this is related but, the car seems to shake a little when the lights aren't working. Has this happened to anyone? If so, how did you fix it?
Old 12-11-17, 11:56 PM
Fixman
Fixman's Avatar
Check the light sensor. It’s on the midle of the dashboard closer to the the windscreen.
Switch the lights on and Use a pice of paper or cardboard t cover it up. And see if you can duplicate the err. If so then it’s probibly that sensor or the connection of the sensor.
Hope this helps you.
Old 12-12-17, 12:16 AM
Mishka430
Mishka430's Avatar
I actually just detailed her today so maybe i have some cleaner on top of the sensor that didn't get wiped off. I'm about to go check it out. Thanks man!
Old 12-12-17, 12:30 AM
Mishka430
Mishka430's Avatar
So i went out and wiped off the sensor, then i used a flashlight to simulate daylight. The lights got bright and went dim as they should but never went 100% out like they did earlier tonight. I guess I'll just have to drive it for a bit another night and see if it happens again. If it doesn't then I'll assume the sensor was just dirty. Thanks agian for your help!
Old 12-12-17, 01:58 PM
Tom57
Tom57's Avatar
Those dash light sensors don't typically fail. More likely this > https://www.clublexus.com/forums/ls-...-at-night.html
Old 12-12-17, 10:20 PM
Mishka430
Mishka430's Avatar
Thanks for that link! I think that is every bit of information a need! I will update if the problem is still happening (haven't driven her since this started) and tell everyone what i find to be the problem/fix.
Old 12-13-17, 02:25 AM
Fixman
Fixman's Avatar
Ok so you detailed the car. On thing happened to few times is I set the interior lites to its diming *** to minimum by mistake win I am cleaning the interior. And if it is at minimum when you such the head lights on the internet gos off. So check that *** if it is set t minimum.
JTone
ES - 5th Gen (2007-2012)
01-07-13 05:14 AM
LuvMyRX01
RX - 1st Gen (1999-2003)
12
12-05-12 06:08 AM
wcntan80
Hybrid Technology
06-26-11 12:02 PM
Phucanese
04-28-06 03:54 AM
slowtan
07-18-02 08:23 PM
Quick Reply: My interior lights switch from night to day ramdomly, whats the fix?
