foam cannons
Typically a foam cannon attaches to a pressure washer. The $20 Foam ones attach to a garden house. These have been referred to as a foam gun. I have both and find that for a quick wash ( car is relatively clean) I use the foam gun, as I don't have to drag out the pressure washer.
Foam cannons should spread a thick coating of suds on the car and will stay there for 4-6 minutes depending on product used.
Foam Guns spray suds on the car but a much thinner coat. It tends to rinse down the panels much more quickly than a foam cannon. Again both units ...depends on product (soap) used and the concentration level.
I think op is referring to:http://www.ebay.com/itm/Foam-Lance-S...kAAOSwTuJYoXzU
I have to say the above works ok, after multiple failed gaskets, and multiple trips to the lowes store for gaskets it finally doesn't leak, if I had to do it all over again Id go for the mtm kit its much higher quality.
FastFord (07-25-17)
Auto Detailing Master
They'll all perform the same function... but the MTM is up to professional use. Higher quality materials and internals. I used the same MTM foam cannon for years and never cleaned it (not recommended ) and it worked great.
I have recently bought the newer MTM PF22 and love it.
I use a foam gun, that attaches to a garden hose, for rountie wash. It's quick and easy imo.
The foam is OK, nothing comparable with a foam cannon, but it does a good job in pre-soaking and rinsing off most of the dirt. I always follow with a hand wash.
I hardly use foam in either a foam gun or cannon with regular hose or high pressure, Imo its functional but mostly for show. I prefer the rinseless method, if done right you can get same if not better results than a traditional 2bucket while saving water, being a lot more time efficient, a lot less clean up afterwards, I use this method as my main form of routine wash even after 20+ hours correcting my paint.
Thanks for all the responses. I ordered a $20 one first to test out and it started leaking already after just one use. So i was just wondering if i should just spend the extra $ to get the MTM hoping it doesn't leak/break after just a couple of uses. Does the MTM also foam thicker all else being equal (same amount of soap dilution and same pressure washer)?
Depending on the weather I still "wash" it occasionally to get the wheel wells and other areas that you wouldn't use a rinseless wash.
[QUOTE=FastFord;9935969]I'm with you! Much more time efficient and the windows don't smear after a down and up cycle.
Depending on the weather I still "wash" it occasionally to get the wheel wells and other areas that you wouldn't use a rinseless wash.[/QUOTE
Id have to agree with you on that one, I too find it much more beneficial to break out the hose on the wheel areas.
[QUOTE=k20trick;9935983]
How often do you guys clean your wheels when doing a rinseless wash? I have to clean my wheels every time I wash my car. If I'm going through the trouble of taking out the garden hose to clean my wheels, then I just wash my car with water and soap.
[QUOTE=Blkexcoupe;9936042]
Well in my case, I am not well at all, so if I do the rinseless thing out comes my little rolling stool and I park my butt in front of the wheel with my assortment of little brushes and microfiber towels, some sort of gentle cleaner and away I go. Yes I get right back to do the barrels as well.
I never use any brush that has metal in it. There are lots of good brushes that are just plastic.
Some how I think there are a few of us with the same affliction.
[QUOTE=FastFord;9936059]
True, I also clean my wheels everytime, but I can easily spend 1-1 1/2 hours fully cleaning the inner barrels only to find out. that the first drive they are toast again. I only clean the faces now with same rinse less solution for the paint, however if I go over 2 weeks or so then I need to brake out the acid and water to rinse off thoroughly.
You seem very ambitious, I used to dedicate an hour or two doing the wheels alone too, but it was too much. The Gary Dean method works great for rinse less. You won't know till you try and tweak it to your preference. You can still use the stool.
