Sam's Club Headlight Restoration Review
Old 06-25-17, 02:58 PM
alchemist
alchemist's Avatar
Default Sam's Club Headlight Restoration Review
The other day I took my 2001 Tacoma into Sam's Club to get new Michelin's put on and noticed a flyer for headlight restoration. For $40 and a 5 year warranty I decided to give it a shot. This is not just an application of 3M or turtlewax headlight compound which only lasts a month, but an application similar to this process in which the material alone would cost ~$40:
http://www.detailedimage.com/Ask-a-P...ation-process/
My truck is parked outside in the sun and elements and really needed some headlight TLC. I thought they did a great job...taped off the front of the vehicle, used sandpaper in multiple steps with varying grits, then polish, then UV-activated clear coat.
Today, I decided to take in the wife's RX330 which needed the headlight restoration as well. Results below. I'll circle back in a year and let you know how they hold up.
BEFORE
AFTER
Old 06-26-17, 02:37 PM
Alexbenz
Alexbenz's Avatar
i've done this myself, you need to touch up on the lights every so often or add a uv sealant every 6 months to a year
Old 06-27-17, 10:27 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
you can use this to seal after polishing
http://www.rustoleum.com/product-cat...a-cover/clear/
professorm (08-07-18)
Old 10-19-17, 01:13 PM
bagwell
bagwell's Avatar
Matte clear? uhh no.
Old 10-19-17, 01:50 PM
Lexuswiz
Lexuswiz's Avatar
I would not use this, go for high gloss. The matte leaves a slight haze to it. I used the matte on my Camry and regret it heavily but I haven't redone it since its holding well, it the yellowing returns ill resurface it again and go with high gloss.
Old 10-19-17, 02:37 PM
EthanS
EthanS's Avatar
I've had no luck with the UV sealants after cleaning up my headlights multiple times. Perhaps it's because I live in AZ, and there is PLENTY of UV to go around.
After polishing the headlights and applying UV sealant on the same car a number of times over the years, I finally decided to try a clear film/tint overlay. It has held up better than any sealant or spray coating thus far. Over a year later and its still perfect. Picked up 4 square feet of clear tint on Amazon for like $15. Easily enough to apply myself because LS400 headlights are flat and rectangular. Might not be quite so easy to apply on other models.
Just FYI!
EDIT: I am certain that if I ever have to remove the clear tint it will leave an adhesive residue on the headlight. However,
1) at this rate, I should never have to remove the film
2) Some Goof-Off or Goo-Gone should clean that residue right off.
Old 08-06-18, 07:51 PM
cdnewton
cdnewton's Avatar
It has been over a year, curious how the lights look ... thanks.
Old 08-07-18, 08:51 PM
professorm
professorm's Avatar
I have been using a product I just discovered Rustoleum Wipe New on my Trim. It says it can also be used to seal headlights. The reviews looks pretty good for headlights as well.
ortizarn
10-08-09 09:34 AM
gsfor
10-25-04 07:45 PM
Quick Reply: Sam's Club Headlight Restoration Review
