taking apart headlight
Old Oct 25, 2004 | 03:46 PM
gsfor's Avatar
gsfor
Default taking apart headlight
i wanted to know what temperature you should put the headlight in the oven at and for how long i couldnt find anything in search thanks guys.
Old Oct 25, 2004 | 04:58 PM
AlphaJZS's Avatar
AlphaJZS
unscrew every screw you can unscrew on the headlight first....(say that 5 times fast, hehe)
pre-heat the oven to 225
let the headlight sit for 10-15 mins...WATCHING IT every minute past 5 minutes so nothing can go wrong...
take the headlight out and separate the lens and the housing at a fairly fast pace.
should be pretty easy... g'luck dood.
Old Oct 25, 2004 | 06:10 PM
b1gredek's Avatar
b1gredek
baking it works a charm, good luck take your time, make sure you reseal it good or else it will get foggy in the future
Old Oct 25, 2004 | 07:45 PM
tiguy99's Avatar
tiguy99
Yup. Just make sure you reenforce the seal by adding more silicone layers to it when its drying in the end. (Meaning when you put it back together) I must reenforce this because these lamps WILL fog up on you if you dont' seal them right. I just finished this project. To add to the grey lexus seal, we added the new clear siliocone sealant on top of the edges when I put them back together this morning.
Enjoy
https://www.clublexus.com/forums/sho...hreadid=138362
cupid0210
Apr 12, 2011 11:09 AM
hemogoblin
Apr 17, 2006 07:06 AM
