IS350 Gasoline and Coolant smell in cabin
Old 05-24-17, 06:25 AM
picklebacn
picklebacn's Avatar
Unhappy IS350 Gasoline and Coolant smell in cabin
I just picked up a 2008 IS350. The interior has a very odd maple syrup smell (seems like coolant) as well as a raw gas smell in the cabin. I have searched the forums and the only thing I could find was that there was a recall for the FPR gasket which my VIN doesn't show outstanding. Smell is more prevalent when windows are down while not moving. Can't smell it from the outside.
Are there any known problem areas on the IS350 to look to identify the gas and coolant smell?
Old 05-24-17, 02:00 PM
Gville350
Gville350's Avatar
Could be mildew from a blocked A/C drain. The fuel through, that's not good at all. Perhaps a professional detailer can recommend a treatment for the carpets/seats/pillars/headliner to help with any smells.
Old 05-25-17, 04:50 AM
picklebacn
picklebacn's Avatar
It is definitely a coolant smell. I have already steam cleaned/ shampooed the carpets, replaced the cabin filter. The smell is coming from the vents for the coolant and gas smell. Not as noticeable with recirculate on, but definitely still there
Old 05-25-17, 05:24 AM
6t6
6t6's Avatar
Antifreeze smell. Sounds like heater core leaking.
Old 05-25-17, 05:48 AM
picklebacn
picklebacn's Avatar
Is this a common issue with the IS series?
Old 05-25-17, 05:54 AM
6t6
6t6's Avatar
Default leak
Not necessarily. It's an age thing.
Old 05-25-17, 05:57 AM
picklebacn
picklebacn's Avatar
I did just notice there is a red residue all over the filler cap on the radiator, might have a leak...
Old 05-25-17, 11:51 AM
Gville350
Gville350's Avatar
Do you mean on the overflow tank? If so, that unfortunately is normal. Also keep in mind that the overflow tank has a short tube that dumps any excess (due to pressure) directly on top of the radiator.
Old 05-25-17, 01:56 PM
andrewwake
andrewwake's Avatar
My 06 IS350 has a gas smell and had that recall already done. I've gotten used to the smell, but a friend of mine noticed it and showed concern. I think I remember hearing from a tech that it's normal for our cars, since they're direct injection and run rich at times.
Old 05-25-17, 05:46 PM
bazzle01
bazzle01's Avatar
Check under rear seat that gasket on top of tank sender is not leaking and hoses secure.
Old 05-26-17, 06:05 AM
Bkhectic
Bkhectic's Avatar
2012 is250 and I've been smelling gas through the vents as well. When in circular mode i don't get any smell but I've checked for leaks and nothing anywhere unless it's a gasket somewhere. Let me know if there's an answer.
Old 05-26-17, 12:27 PM
bangdangvn
bangdangvn's Avatar
Had the same thing for a long time in my 06 250. Traced the fuel leak (o ring) by high pressure pump on passenger side near battery.
Yodog (10-04-23)
Old 05-26-17, 04:49 PM
5nX37
5nX37's Avatar
There's a recall on fuel line fitting seal located near the firewall side engine bay. I had occasional gas fume smell in my car before I had the recall done..
Old 05-28-17, 12:00 AM
whitebeast
whitebeast's Avatar
I have same problem and my issue is fuel leak at the seal for the for the fuel injector array- not cover under re-call or warranty.
Yodog (10-04-23)
nikovdh
05-24-18 02:54 PM
Ericspyder
11-14-17 09:58 AM
5nX37
07-03-17 12:56 PM
Adam0412
01-25-13 12:16 PM
LeXuSrAcIn
03-15-10 02:20 PM
Quick Reply: IS350 Gasoline and Coolant smell in cabin
