Help needed 93 LS 400 non responsive when I push the gas paddle
Old 05-14-17, 09:31 AM
Ilovemycar
Ilovemycar's Avatar
Default Help needed 93 LS 400 non responsive when I push the gas paddle
Hi I need your help with my 93 LS 400. My car cuts off but starts right back up also it will lose all power while driving, it stays running but I could floor the gas paddle all the way to the floor but the car remains non responsive meaning the engine won't rev up. It gets a rough idle. I have had this car for 17 years. It has 291k miles & transmission was replaced at 171k. I took it to the dealer they changed throttle position sensor but kept the car for 3 weeks & said they couldn't replicate the problem. Dealer told me that fuel air mix is a little off but there is no code showing up. I also replaced fuel pump along with plugs & wires, air filter & fuel filter but the car still has the same symptoms. Help me guys.
Old 05-22-17, 10:52 AM
wakebord99
wakebord99's Avatar
When you say " it will lose all power while driving"... do you actually mean power or are you referring to throttle response?
Old 05-22-17, 11:58 PM
dicer
dicer's Avatar
Maybe its the ecu problem go to the LS400 forum.
Old 05-24-17, 10:10 PM
Ilovemycar
Ilovemycar's Avatar
no throttle response is what I mean. I press on the gas but the rpm's will not go up but the engine remains running & all others functions remain normal accept the engine is non responsive to gas peddle
Old 06-12-17, 06:44 PM
SAK74
SAK74's Avatar
its called Limp Mode
sayow
19
04-15-14 12:12 PM
Andyls
15
11-16-13 10:13 AM
mklaah
28
10-03-11 07:06 AM
hobojoe
06-27-07 09:38 PM
twinz
08-29-06 09:55 PM
Quick Reply: Help needed 93 LS 400 non responsive when I push the gas paddle
