how to make a 97+ cluster work on a pre-97 walkthrough
Old 04-24-17, 10:40 AM
megamax
megamax's Avatar
Default how to make a 97+ cluster work on a pre-97 walkthrough
So I was looking for a faq and to no avail so I searched the net found some wiring diagrams which I couldn't understand, but I found 1 particular diagram that made life/this project a breeze. so here is what you will need.
-a pre 97 cluster scrap/throw away. you will just need the rear board with the plugs
-a 97+ cluster with all 4 plugs and enough pigtail length
-wire, enough wire (I brought one of these)
http://www.harborfreight.com/400-ft-...use-61527.html
-soldering iron, solder, and a mini torch.
alright let's get started.
the pre-cluster has 3 plugs while the post cluster has 4 total, the name of the game is getting the right wires to match up.
the numbers of the pins are on the plastic connectors
LUCKILY I came across a thread that gerrb had, and someone had made this spreadsheet, .
now you could solder directly into ur cluster pigtail, me I wanted something easier so I made a jumper harness.
first you want to singe the board with the cluster pins in them. you need to heat the solder and the FEMALE plugs will fall out, like so.
next up is trimming the sides so you can have as much pin exposure as possible.
now you are NOT going to use every pin, but instead of counting them. I went ahead and just pig-tailed them all.
3 hours and some rubber tape later.
so with the right wiring diagram it's time to cut and solder. the pins are again numbered and the colors of the wires are perfect.
so 4 hours later.
as you go on you will letter which plug is which, again follow the pin outs and the colors of the wires, all the ones you can fold back into the loom.
and done!!!!
and finished product. this cluster is more modern and it actually gives me accurate mph and fuel.
Old 04-24-17, 10:59 AM
gerrb
gerrb's Avatar
good job Jim
Old 04-24-17, 11:04 AM
davvv
davvv's Avatar
Nice write up! What i did was just replace the whole dash harness, but this looks to be the next best bet since the dash doesnt have to come off.
Old 04-24-17, 12:25 PM
t2d2
t2d2's Avatar
Impressive write-up. Would it be possible to just de-pin the "pre" connectors and plug them into the right spots in the "post" connectors, using your road map? That seems like it would be a lot easier if the pins and connectors are sized the same. Wire length might be an issue, though, as the harness is way too short as it is, and might be incapable of reaching new locations on the board.
Old 04-24-17, 02:02 PM
megamax
megamax's Avatar
no because the post board isn't a board, if you look you see pins and that green film on the back.
Old 04-24-17, 02:04 PM
megamax
megamax's Avatar
Originally Posted by gerrb
good job Jim
thanks g, couldn't had done it without ur thread. now onto some bigger fuel lines..
Old 04-24-17, 02:24 PM
t2d2
t2d2's Avatar
I don't understand what you just said, and I don't think you understood what I was asking. I'm talking about de-pinning and re-pinning the connectors, nothing to do with the board.
Old 04-24-17, 07:54 PM
megamax
megamax's Avatar
ah, de pins, well the pins on all but the orange plug are different on the 97+.
Old 04-24-17, 08:18 PM
t2d2
t2d2's Avatar
The pins themselves or the wires and connectors?
I still don't think we're on the same page...
Old 04-25-17, 05:08 AM
megamax
megamax's Avatar
the pins themselves, that means the connectors are different also.
Slow_Sc3
Performance & Maintenance
20
04-17-17 11:59 PM
Catracho30
SC400 / 300 Classifieds
05-14-14 07:06 AM
S142jz
12
09-05-10 05:43 AM
S142jz
06-01-10 07:47 PM
O. L. T.
05-24-05 02:06 PM
Quick Reply: how to make a 97+ cluster work on a pre-97 walkthrough
