Installing oem trunk spoiler
Old 04-22-17, 11:17 PM
Jwild909
Jwild909's Avatar
Default Installing oem trunk spoiler
Hi All,
I want to install an oem spoiler that I bought used but I'm worry about water getting into the holes that need to be drilled. How do I make sure that no water gets under the spoiler and in the holes? Do I add a sealant after I tighten the bolts down or before? If I add it before how do I do it so it doesn't cause an issue when I tighten the bolt all the way down? I don't trust only using the 3m tape and took my aftermarket one off that was only held on by tape so the holes will be drilled for the oem just need to know how to seal them properly so the spoiler can sit flush. Any help is appreciated.
Old 04-23-17, 07:25 AM
bbaugher47
bbaugher47's Avatar
I have my OEM rep held on by tape right now. I have been thinking about bolting it down as well. I would think a rubber washer would do the trick. But honestly not 100 % sure.
Old 04-23-17, 07:52 AM
Brian7
Brian7's Avatar
Originally Posted by Jwild909
Hi All,
Why not just use tape to hold it down? That way if you ever decide to go spoiler-less, you won't have any holes at all
Old 04-23-17, 12:01 PM
mandyfig
mandyfig's Avatar
Use automotive grade double sided tape. All you need. You will not be able to just yank it out even if you tried. Most of the accessories which are exterior are held by 3M tape.
Old 04-23-17, 07:18 PM
Aspect
Aspect's Avatar
3M makes some great double sided automotive tape. When I was installing my spoiler I put it down in the wrong spot and I almost cracked my spoiler trying to rip it off. Check out 3M VHB. Nothing is taking your spoiler off after that.
Old 04-24-17, 06:11 AM
Tungstn-IS
Tungstn-IS's Avatar
I wouldn't worry about the tape, my spoiler has been held on by 3M tape for the past 8 years without an issue. Same goes with all these people who have the roof spoiler, it's not like they're drilling them into the glass. The tape works just fine.
Old 04-24-17, 11:20 AM
mandyfig
mandyfig's Avatar
3M automotive tape, no issues.
Old 04-24-17, 12:45 PM
MikeyK02
MikeyK02's Avatar
3M automotive tape...all you need
Defratos
IS F (2008-2014)
20
07-24-14 06:32 AM
IS25Heaven
CL of Southern California
13
10-02-09 12:31 AM
SC3coupe
07-23-07 01:04 AM
Lupin5
04-18-06 10:16 PM
e-man
05-01-04 11:14 AM
Quick Reply: Installing oem trunk spoiler
