NC Figs caster arm bushings
Who ever is interested in these caster arm bushings please note, unless he purchased two sets of these, they do not come with 60 and 65mm sized bushings. You either purchase a 60mm from Mike if your car is early '98-00, or 65mm '01 and up. Don't base what size you will need solemnly on the year either, I had a GS that was a '99 but was made in January of 2000, and infact came with 65mm bushings not the 60's. They are $155 on shopfigs.com
I believe the seller may be confused due to the fact that these bushings are not one piece, but consider each side 3 pieces, or actually 4, one center peice that gets pressed in the caster arm, and two end caps which are a smaller diam. Poly cap, and the 4th part just being the core that slips in through the center all three peices where you would be slipping the mounting bolt through to hold everything together.
Seller, measure the OD of the two peices you have that are invaded in the metal, it'll be either 60, OR 65mm. That's what buyers must know. Good luck.
Before you try calling out someone, maybe you should pm them before acting like the big bad wolf.
Mike sent me the wrong size orginally 65mm inserts in which he had to resend me 60mm inserts. So i do in fact have both 65 and 60mm inserts in my possession. Buyer can choose which insert they need and i can return the other to mike. Thanks for all your information for interested buyers but i do have both insertss.
bentleymp2
Suspension and Brakes
Jan 8, 2016 09:28 AM
aarondds
Oct 6, 2010 03:47 AM
johnee78
May 16, 2010 07:53 AM
lyonkster
Apr 27, 2010 09:55 PM
