TX SC300 2JZGTE, 2JZGE, Nissan, Performance
Cleaning out the garage after car project and need to get this stuff out. Posting on a couple forums so first come first serve. I have pictures and all of the stuff works. All prices are negotiable and shipping will need to be discussed. Really trying to clean out the clutter.
Nissan
Nissan oil filter 4 15208-55Y00 $2.50
Nissan air filter 1 16546-0Z000 $4.50
Nissan belt 1 11920-31U02 $9.00
Nissan fuel filter 2 16400-0M200 $4.50
Nissan Spark Plugs 6 PFR5G-11 $3.50
Axxis Metal Master 300ZX Front pads 1 23-460-01 $20.00
2JZGTE
6-speed, US Spec, TT ECU 1 89661-14520 $200.00
oil pan hose flange 1 $10.00
rear main seal 1 $10.00
resistor pack bracket 1 $5.00
WASTEGATE=90910-12115 1 $30.00
IACV= 90910-12114 1 $30.00
VSV with breather 2 $20.00
lower runners (intake) 1 $20.00
fuel rail 1 $20.00
JDM down pipe flange 1 $5.00
TT pressure tank with VSV 1 $15.00
SC300 2JZ
pulleys 1 $4.50
transmission brace 1 $22.50
auto shifter bezel 1 $18.00
coil pack 1 $10.00
igniter 1 $10.00
power steering res 1 $10.00
transmission mount 1 $10.00
fuel pump hanger 1 $10.00
fuel tank line 1 $5.00
Radiator (Auto) 1 $35.00
Carbon Canister 1 $15.00
Cruise Control 1 $25.00
ABS actuator 1 $50.00
MISC
Odyssey PC625 Battery 1 PC625 $50.00
Fragola 10*18*1.5 adapter 1 $3.00
oil line (-10) 1 $20.00
adapter (-10) 1 $15.00
wastegate flange 35mm 1 $25.00
60-1 turbo 1 $45.00
Marlin Heavy Duty Bearing Retainer for R154 1 $45.00
aluminum -10 femaile oil return flange 1 $10.00
aluminum -3 male oil feed flange 1 $10.00
silicon coupler 2.5 to 3.0 elbow 1 $10.00
silicon coupler 3.5 to 3.0 reducer 1 $10.00
black 3" couplers 2 $5.00
gray 3" couplers 4 $5.00
Blitz 60mm fuel pressure gauge 1 $45.00
Blitz 60mm Boost Gauge 1 $45.00
Blitz 45mm EGT Gauge 2 $30.00
Blitz Sequential Boost Controller Solenoid 1 $15.00
SBCi-D controller boxes 1 $10.00
SBCi-D Power meter 1 $35.00
Sentra Electric fans 1 $30.00
all pictures can be seen at www.photobucket.com/iconyqforsale
Nissan
2JZGTE
fuel rail 1 $20.00
SC300 2JZ
pulleys 1 $4.50
coil pack 1 $10.00
igniter 1 $10.00
MISC
60-1 turbo 1 $45.00
ummagawd
Feb 22, 2004 03:31 PM
