TX WTB 98 LS400 stock springs
Old Mar 11, 2012 | 11:41 PM
xinkid's Avatar
xinkid
Default WTB 98 LS400 stock springs
WTB 98 LS400 stock springs in good condition.
Old Mar 12, 2012 | 06:38 PM
borundad's Avatar
borundad
i thinh they are the same for 95-00. If so I have a set in good condition.
Old Mar 12, 2012 | 11:30 PM
xinkid's Avatar
xinkid
according to oemlexusparts.com 95-97 springs are different from 98-00
Old Mar 17, 2012 | 01:11 PM
SpencerT's Avatar
SpencerT
95-00 uses the same system.
they are the same.
I just replaced my springs and shocks.
they are still good though. Ill sell you the old ones if you want them
Old Mar 17, 2012 | 05:42 PM
borundad's Avatar
borundad
That's what I thought also
they are the same.
Old Mar 18, 2012 | 02:31 PM
SpencerT's Avatar
SpencerT
We are correct.
If that website says they're different, then its not right.
Old Mar 18, 2012 | 07:31 PM
xinkid's Avatar
xinkid
Hi,
Thank you for your offers.
I did some more research, front springs have different part numbers while rear springs have the same part numbers. I wonder what the difference is between 97 and 98 front springs.
front spring
1997 4813150070
1998 4813150100
http://lexus.sewellparts.com/oem-cat...S400-1997.html
http://lexus.sewellparts.com/oem-cat...S400-1998.html
rear spring
1997 4823150120
1998 4823150120
looking at front shock absorbers
1997 4851059106
1998 4851059106
front strut mount (SUSPENSION SUPPORT ASSEMBLY)
1997 4868050090
1998 4868050100
It looks like the shocks are the same but the mounts are not.
I believe the mounting points are the same since aftermarket struts specify 95-00. The only significant difference might be the front spring rates since I read somewhere 98+ has 10% more roll stiffness without sacrificing ride quality.
Old Mar 18, 2012 | 07:33 PM
xinkid's Avatar
xinkid
BTW, I will do more research to find out exactly that is the difference between those part numbers.
Old Mar 20, 2012 | 12:38 PM
SpencerT's Avatar
SpencerT
Have you been convinved that the 95-97 is the same yet?
Because I just found out that the new springs I just put on were originally bought for a 98-00 not mine which is a 95. And the fit perfectly and feel perfect
I have my entire stock strut assembly. thats stock springs, shocks, mounts, insulators, and bumpers.
Everything but the springs have 40K on them.
I asume the springs are original and have 180K
but they are in perfect condition.
Let me kno what you need
Old Mar 20, 2012 | 12:48 PM
xinkid's Avatar
xinkid
Hi Spencer, can you send me a hi-res picture of your complete strut assemblies?
Did you replace the struts, mounts, insulators and bumpers 40k ago so you know that for sure?
Thanks
BTW, I'm convinced 95 and 98 have the same mounting points, only diff might be in the spring rate but it doesn't matter to me because I drive the car super easy, don't need to extra roll stiffness.
Old Mar 22, 2012 | 10:41 AM
SpencerT's Avatar
SpencerT
ill pm you and post the pictures in the thread I made for these struts
Old Mar 22, 2012 | 03:01 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
mounting points are the same and for all practical purposes 95-97 and 98-00 have interchangeable spring/shock assemblies.
Old Dec 27, 2012 | 08:47 AM
steedls400's Avatar
steedls400
Do you still have the set?
Old Dec 28, 2012 | 05:49 PM
borundad's Avatar
borundad
Yes I do have it
ihiryu
Jun 4, 2012 11:44 AM
z32scottie
May 20, 2010 09:16 PM
Tony2Carte
Mar 15, 2009 03:20 PM
abobiznow
Aug 18, 2006 06:29 AM
titesi
Jan 31, 2006 04:56 PM
