iJDMTOY Super Bright LEDs & HIDs!
We were founded in 2004 and we have now become one of the largest automotive LED lighting retailer in the U.S since then. We carry most replacement LED bulbs for most vehicles, aftermarket HIDs (kits and bulbs) in various sizes, LED DRL lamps (Audi style, Mercedes-Benz E-Class style, etc) and much more!
If you guys have any questions regarding lighting for your car, feel free to PM me and I'll help you out the best I can.
$89 SHIPPED WITHIN THE U.S.
http://store.ijdmtoy.com/HID-Light-Bulbs-Xenon-Headlight-p/hid_d4s_d4r_d4c.htm
Looking to replace the dull looking factory OEM HID color? Look no further, get some Garax D4C HID replacement bulbs!
D4C is a hybrid version of D4S and D4R, so it will fit and operate just like how your stock bulbs do. We have 6000K (Ultra White), 8000K (Brilliant Blue), 10,000K (Deep Blue), and12,000K (Violet/Purple) colors available and ready to ship!
These bulbs are made in Japan so you know the quality and craftsmanship is all there.
iJDMTOY 35w Digital HID Conversion Kit
http://store.ijdmtoy.com/Slim-Digital-Ballast-Xenon-Headlights-p/hid_conversion_kit.htm
Upgrade your fog lights or headlights (if you have halogen lights) with our 35w Digital HID conversion kit! HIDs provide up to 3 times more output, use less power, and produce less heat than traditional incandescent bulbs.
FEATURES:
- Ultra slim waterproof digital HID ballast
- Internal regulator chip that maintains a stable current to increase the life span of the HID bulb
- Reverse polarity protection
- Shock resistant ballast protection
- Completely plug and play, no extra components required
Available in 3000K, 6000K, 8000K, 10,000K, and 12,000K colors.
6 PC Direct Fit Interior LED Package for the 2006-2011 Lexus IS/F
$47 SHIPPED WITHIN THE U.S.
This package includes:
3 x 18-SMD LED Panels for the front map lights
1 x 36-SMD LED Panel for the center dome light
2 x 18-SMD LED Panels for the vanity mirror lights or side door lights
These are only available in Xenon White and they are completely plug and play!
We also have other LED packages available for other cars such as the 2002-2006 ES300/330, older generation GS and IS models, 2001-2006 LS430, 1992-2001 SC300/400, and much more! Just PM me for details.
iJDMTOY 2.5W High Power LED Reverse Lights
$24 SHIPPED WITHIN THE U.S.
These should replace the stock reverse lights for most of the Lexus vehicles out on the market these days that use a 921/912/906 sized bulb. These are perfect especially if your stock LED bulb is pointing directly behind the vehicle since this is a focused projector light.
The output is approximately 500 lum
iJDMTOY 5-SMD T10 LED Bulbs
$16 SHIPPED WITHIN THE U.S.
These bulbs are perfect for the license plate and parking light or any bulb on the vehicle that uses a 168/194/2825 size. These are very popular among our customers and you will definitely see why once you pick up a set.
These are available in Xenon White, Ultra Blue, and Brilliant Red.
iJDMTOY 120-SMD LED Bulbs
$56 SHIPPED WITHIN THE U.S.
These bulbs are a perfect upgrade for your fog lights as most Lexus models use the 9006 bulb size for their fog lights. These are completely plug and play and provide you a beautiful 6000K HID color without the expensive cost. Although these do not provide the same output as HIDs, they are still quite bright.
These are also available in 9005 so you can definitely use them for your DRLs as well! You'd have to get the decoder kit separately though which available here.
This is only available in 6000K Xenon White.
iJDMTOY LED Clear Lens Bumper Reflectors
http://store.ijdmtoy.com/Lexus-Toyot...tm&click=35328
$30 SHIPPED WITHIN THE U.S.
This will include 2 x 13-LED Chip Bumper Reflectors that will fit the following:
2008+ Lexus IS-F
2003-2009 Lexus GX470
2011+ Toyota Sienna LE/SE/XLE
2009+ Toyota Matrix
2009+ Toyota Venza
These are only available in Red and are a direct replacement for the vehicle's listed above. They come with 3 wires: Red Wire (connect to tail light positive), Yellow Wire (connect to brake light positive), and a Black Wire (connect to ground)
iJDMTOY 60-SMD Switchback 7440 Single Filament LED Bulbs
http://store.ijdmtoy.com/7440-Single...tm&click=35328
Before, your original 7440/992 sized turn signal bulbs would only light up when you use the turn signal. However, we now have a new revolutionary 7440 switchback LED bulb that can light up as your parking lights and still function as your turn signals. During parking light mode, it will light up as Xenon White and when you use your turn signals, they will flash Amber Yellow.
These lights come with a thin, heat resistant wire that can be tapped to the parking lights for power. The wire is thin enough that it can be twist locked in the socket housing of your turn signals (the wire is strong enough to be crimped, but take caution so it does not get cut).
Just ask for Thura and I'll help you out.
Most of the Lexus vehicles are already LEDs stock.
Yes, we typically do not discount HID kits that much, but if you order over $100 you can get 20% off!
Sweet! Let me know if you run into any problems.
http://store.ijdmtoy.com/Lexus-IS250-IS350-Direct-Fit-LED-Interior-Lights-p/pkg_lexus_df_03b.htm
This direct fit panel package is much, much brighter than the traditional LED bulb replacements. The kit includes 3 pieces of 18-SMD LED Panels for the front map lights, 1 piece of the 36-SMD LED Panel for the center dome light, and 1 pair of 18-SMD LED Panels for the vanity mirror lights (or side door lights).
Many of my customers have stated that these lights turn your interior into daytime at night when the lights are on (not exaggerating at all, these are very bright)
These are only available in 6000K Xenon White.
5220 Rosemead Blvd
San Gabriel, CA 91776
You can give us a call at (626) 872-1127 if you get lost or have any questions. We're open from M-F 9AM-5:30PM (for the store front, 6PM for the warehouse).
I'll post this up in the SoCal section to get this test going, once we have it tested and it's confirmed working, I'll post this up in the thread for sale!
Vinceeeeeeeeennt!
