Truck Lid Problem
Old May 27, 2026 | 10:06 AM
Carter85258's Avatar
Carter85258
3rd Gear
Default Truck Lid Problem
I am having a new problem on my 2002 SC430 with opening the trunk and I am hoping someone can tell me what is going on and how to fix it. Here’s the issue.
When I open the trunk lid to access the trunk, the back of the lid (nearest to the cockpit) catches on the piece at the back of the seating area and flips it up. It then goes on by it and the piece flips back down.
This doesn’t happen when I close the roof or open the roof. In these cases, the trunk lid doesn’t catch on anything.
Does anyone know why I am getting this issue and how to fix it?
Thanks.
File Type: mp3
Old May 27, 2026 | 11:38 AM
DshngDaryl's Avatar
DshngDaryl
Does your trunk look like it is aligned properly? Are all the gaps equal?
Old May 27, 2026 | 12:14 PM
Carter85258
3rd Gear
Thanks for the idea. The alignment looks good. Also, I received a suggestion to lubricate the gasket around the trunk lid. When I got it, I checked the gasket and it was very dry. So, I looked around for my tube of SIL-Glyde and applied it. Now the trunk opens without sticking. Made my day!!
Old May 28, 2026 | 01:34 PM
DshngDaryl's Avatar
DshngDaryl
Old Today | 12:15 PM
timstich's Avatar
timstich
2nd gear
One more trunk point. If you accidentally push the trunk opening button instead of the gas door button and ignore the red indicator light on the dash, the trunk light will be on. Since the trunk door is very heavy, you can drive around and not notice this. The trunk light will eventually kill your battery. Ask me how I know. :-P My daughter did that.
Old Today | 03:34 PM
Carter85258
3rd Gear
Default Good Point
Thanks. This is a good point. It may be why I had to recently get a new battery even though i didn't know why at the time!
Segullah
Jun 7, 2024 02:25 AM
sixt33n
Mar 15, 2016 09:45 PM
czr73
Sep 25, 2015 06:27 PM
RuCuS81
Jul 6, 2011 05:27 PM
Rustito
Sep 22, 2009 06:30 PM
