2018 transmission fluid temp check
Old Yesterday | 06:17 PM
gxLover1's Avatar
gxLover1
9th Gear
Default 2018 transmission fluid temp check
I am getting conflicting reports
for 2018 should temp be 104°F - 113°F or 115°F-126°F
I know I could also do the wire jumper and the D-N diagnostics.. but I want to double check temp with scan tool as well....
Old Yesterday | 08:01 PM
guzzy92fs's Avatar
guzzy92fs
I did mine using the kingbolen k7, its the best tool i have found cost-effective i also solved my evap issue as well if it helps here it is https://amzn.to/4saM9XQ
Old Today | 04:32 AM
iwashmycar's Avatar
iwashmycar
Ive used and heard the 115-130 is range.
Old Today | 04:59 AM
BenCSVT's Avatar
BenCSVT
115-126 F is the correct range.
I pull my check plug as soon as it hits 115 to keep the fluid level at the high end of the allowable range.
Cycle through your gears as it warms up.
Old Today | 05:00 AM
kgbagent1's Avatar
kgbagent1
115 to 126 F per Lexus TechDoc
Dsmdriver2588
Oct 16, 2025 03:57 PM
bmuguerza
Aug 29, 2016 07:11 AM
mylexus350
Dec 5, 2011 09:26 AM
ron36330
May 26, 2003 01:17 PM
