2018 transmission fluid temp check
I am getting conflicting reports
for 2018 should temp be 104°F - 113°F or 115°F-126°F
I know I could also do the wire jumper and the D-N diagnostics.. but I want to double check temp with scan tool as well....
I did mine using the kingbolen k7, its the best tool i have found cost-effective i also solved my evap issue as well if it helps here it is https://amzn.to/4saM9XQ
Dsmdriver2588
Oct 16, 2025 03:57 PM
tlipcsey
Maintenance
Jul 13, 2022 12:51 PM
