Electrical gremlin
I have a 2009 es 350 that has been a fantastic reliable vehicle. It has become an extra car since my son moved out and it went from a daily driver to maybe a weekly. We had some really heavy rains and I did not know that a sunroof drain was clogged so when I opened the car I found the at water had come down the passenger pillar and the carpet floor was pretty soaked.
I went to start the car and when I pushed the button it would start then immediately die.
The second attempt to start would be met with cranking only.
i read about leaks could cause problems with the computer so i put a dehumidifier and fan in the car over night.
Next day i went to start and the push button did nothing at all. I disconnected battery several times, touched cables together hoping to reset ECU and still had same results. I checked all fuses including th link bar still no luck.
i changed the battery in the key fob. Nada.
The fob works to online/lock doors. I made the mistake of holding down button so all windows roll down including sunroof. Now windows cannot be rolled back up.
i have power to the seat and door locks and interior lights, nothing else. No radio, climate control, dash gauges, ignition button, trunk, sunroof, windows. From web research it sounds like a bad immobilizer and possible ECU. My plan was to tow to mechanic on Monday but now with the windows inoperable I have to make sure they have inside space since it rains every day here.
sorry for the long post. Any help appreciated. Thanks in advance.
I pulled the carpet and padding up on the passenger floor side. It was very wet.
i made the mistake of pressing buttons on the key fob and held the button down so all the windows and sunroof opened.
it rains here everyday. I have a car cover on it and placed cardboard on top of the sunroof so it won’t cave in.
Since it won’t go to accessory mode on the ignition a code reader won’t work.
I have bees ruining a fan and a dryer in the car for the last few days.
Jbobrelly
Oct 4, 2023 10:42 AM
rajgill
Jan 12, 2023 06:48 AM
