What is the Timing for idle and the timing for advance for sc 300
Old 05-07-24, 08:03 AM
Joan
1st Gear
Joan's Avatar
Default What is the Timing for idle and the timing for advance for sc 300
What is the ignotion timing
Old 05-08-24, 04:05 AM
RXRodger
RXRodger's Avatar
Exactly what are you trying to do, set the timing? If so, there is a procedure for jumping the ecu pins and then you set it to 10 degrees btdc. Are you asking for some other reason? Depends on a few things if so.
Gearhead75
Maintenance
46
01-07-20 03:23 PM
Bankswood
10-23-12 10:21 PM
cadynlx
Maintenance
12-04-08 05:47 AM
abutler696
03-08-02 07:36 AM
Quick Reply: What is the Timing for idle and the timing for advance for sc 300
