5 qt. oil jugs not exactly 5 qts?
Old Oct 4, 2017 | 09:01 AM
JT2MA71's Avatar
JT2MA71
Default 5 qt. oil jugs not exactly 5 qts?
Question for those who buy 1 gal. or 5 qt jugs of oil when doing their oil changes. I bought two 5 qt. jugs of Mobil 1 EP and did my oil change last weekend. I poured .2 quart out into a spare empty container and emptied what's left into the crankcase. After warming up and letting the oil settle for a few minutes, I checked the level and it's about 3/8" above the top dimple. Is it overfilled? Were the volume in the new oil containers not accurate? Or 9.8 quarts should be over the top dimple on the dipstick? Thanks!
Old Oct 4, 2017 | 10:26 AM
16GSF00336's Avatar
16GSF00336
Maybe, because 1-Gallon = 4-Quarts
By the way, I used 9-quarts and I was GTG...And thats w/a Oil filter too...
Please, validate your units...
Sounds like over fill to me...
Old Oct 4, 2017 | 10:40 AM
JT2MA71's Avatar
JT2MA71
LOL, yes I know 1 gal. is 4 qts. I just mentioned both bulk containers that are available. Sorry if my info is confusing. Again, I bought two 5 quart jugs, poured out .2 qt from one of the containers, and poured what’s left (9.8 qts) into the crankcase. But, after measuring with the dipstick, it’s 3/8” above the top dimple. So you are putting .8 qt less than factory spec capacity, where is your level as indicated by the dipstick? Thanks!
Old Oct 4, 2017 | 11:23 AM
ssmoked's Avatar
ssmoked
The container has the right amount of oil. It’s a well known fact that 9.8 quarts will overfill the engine. Do a quick search and you will see most owners had overfill cases from the dealer (happened to me 3 times). I believe the correct amount is 9.2 quarts with a filter change
Old Oct 4, 2017 | 11:33 AM
JT2MA71's Avatar
JT2MA71
Great! Thank you!
Old Oct 4, 2017 | 08:29 PM
lexusrus's Avatar
lexusrus
Maybe there are still some old oil in the engine/crankcase/reservoir that can't be drained out?
Old Oct 5, 2017 | 05:18 AM
4TehNguyen's Avatar
4TehNguyen
cuz you cant get every drop of oil in the engine drained. If I had to fill a 9.8 capacity I always round down and intially fill with 9.0 even, then you check oil level and top off as needed
Old Oct 5, 2017 | 07:34 AM
JT2MA71's Avatar
JT2MA71
This is how I’ve always done it. This last time was the first that I got 5 qt containers and did the re-fill the way I did. I guess I just never really kept track of how much I put before, I just top off after warming up with 9 qts.
So anyway, I just loosened the filter housing and drained out about half a quart and now it’s at the top dimple of the dipstick.
Old Oct 5, 2017 | 07:57 AM
WolfManRCF's Avatar
WolfManRCF
Found this in the owners manual.
My experience is that for an oil and filter change, adding 8.8 L (9.29 US liquid quarts) will put the oil level EXACTLY on the top dimple of the dip stick.
Assumptions: car must be level, allow old oil to drain fully, after fill up warm up car wait at least 5 min check level on dip stick.
Wolfman
Old Oct 5, 2017 | 10:29 AM
JT2MA71's Avatar
JT2MA71
I always take time when draining old oil. While we all know we can’t really get rid of every drop of old
oil, but I make sure the oil filter housing is completely drained, that’s easy. And then I leave the pan drain plug out while front of car is up on ramps. I wait a good bit of time til hardly any oil comes out.
I just didn’t know that the 9.8 qts spec. in the factory manual is actually too much. Now I know it’s 9.3. Thanks for all the responses!
Old Oct 5, 2017 | 05:59 PM
shadow1118's Avatar
shadow1118
why would the manual specify otherwise? do you think they rushed it? or just like human mistake?
lysis250
May 31, 2014 06:12 PM
reisjdmd
RX - 1st Gen (1999-2003)
17
Jul 30, 2012 08:08 AM
RocketGuy3
May 9, 2011 01:03 PM
SClean4
May 28, 2009 03:01 PM
rx93
25
Dec 24, 2006 10:45 AM
