NX - 1st Gen (2015-2021)
NX Phone holder recommendations (merged master thread)
Old Jul 22, 2017 | 10:20 AM
  #91
user 2920842's Avatar
user 2920842
4th Gear
Originally Posted by oldwineguy
I use a ProClip
I am interested in installing a ProClip, it looks like the best solution for my needs. Could you post a picture from the driver's position of the mount and the mount with the phone? I'm curious how it looks when it;s installed and if if blocks the screen.
Thanks in advance.
Brian
Old Jul 22, 2017 | 11:00 AM
  #92
dvan7286's Avatar
dvan7286
Default Phone mount
Thanks in advance.
Brian
I can't figure out how to add a picture but there are pictures on the Amazon page for the wizgear. I looked up information on the pro clip and it is a permanent installation. The wizgear has a padded clip and easily removed and does not cause damage.
Old Jul 22, 2017 | 10:18 PM
  #93
oldwineguy's Avatar
oldwineguy
Thanks in advance.
Brian
I'll tried a bunch of different mounts and though cheaper, none work as good as the ProClip. I moved mine over to the right a little to make sure it cleared the NAV screen, but is still easy to acess.
The ProClip is not a permanent installation, it can be removed with no damage.
Old Jul 23, 2017 | 01:25 AM
  #94
zkl2003's Avatar
zkl2003
Default iOttie Easy One Touch Mini CD Slot Car Mount Holder
You can turn the mount more to the left toward you and it won't bother you to shift gears at all. even it does look super close and on the way. The only down side is that it might block the little storage area above the CD drive.
Old Jul 23, 2017 | 02:09 AM
  #95
dchar's Avatar
dchar
This is my favorite phone mount. Allows easy mounting and dismounting of phone without needing magnets or weakening and blocking air vents.
Old Jul 23, 2017 | 05:47 AM
  #96
Lex2000TL's Avatar
Lex2000TL
I use magnetic holder. It holds the phone very securely and I do not have to fiddle with clamps to place phone on or to remove it. The holder itself is attached by 3M tape and can be removed without any damage to a dash trim.
Old Jul 23, 2017 | 11:11 AM
  #97
LHLXD's Avatar
LHLXD
Old Jul 23, 2017 | 12:00 PM
  #98
zkl2003's Avatar
zkl2003
Same here!! I also like to avoid blocking air vents or anything that is easy mounting rather than the one hard to dismounting. Cheers!
Old Jul 24, 2017 | 06:34 PM
  #99
user 2920842
4th Gear
Thanks, that looks better than I envisioned it from the pictures on the ProClip site.
Old Jul 24, 2017 | 07:03 PM
  #100
Lazerboy's Avatar
Lazerboy
Have you tried to put it in the dash upward and make a kind of HUD display out of it? I know there a couple of HUD app that lets you do this.
Old Jul 24, 2017 | 08:30 PM
  #101
oldwineguy's Avatar
oldwineguy
One of the things I like about it versus many of the other ones shown here is that it keeps the phone up more at eye level instead of having to look down at it if needed.
Old Jul 25, 2017 | 09:08 AM
  #102
aztr0's Avatar
aztr0
Like LHLXD above, I got an Anker magnetic car mount. It is small and works great. The magnet is strong and keeps my iPhone 7 plus with case stuck on tight. When I was testing it by trying to shake the phone off before mounting it barely moved. Would recommend if you're one of those who don't want a big mount that's in your face.
Old Aug 1, 2017 | 02:17 PM
  #103
spins123's Avatar
spins123
Using the iOttie mount. So far so good.
Old Nov 28, 2017 | 03:36 AM
  #104
lhcox's Avatar
lhcox
Default cell phone mount lexus nx
Is there a cell phone mount that works with the NX?
Old Nov 28, 2017 | 09:23 AM
  #105
typocl's Avatar
typocl
I use a magnet vent holder in the left vent. Here's some others:
https://www.clublexus.com/forums/nx-...-location.html
