Sponsored by: CARiD
changing HID bulbs
Old Oct 17, 2005 | 06:18 PM
rominl's Avatar
rominl
exclusive matchup
https://www.clublexus.com/forums/sho...&highlight=d2r
got this link from help of MikeM. and credit to ShinChan as well
thanks!
Old Nov 13, 2005 | 09:13 PM
AJL's Avatar
AJL
Registered User
If lexus bulbs are 4300K, and that is the only legal hid...what are the audi's that are much bluer...almost purplish (or was it infinity/nissan)...Anyways...All I have to do to get bluer HIDs is to replace the bulb for a 6000K? will it be noticibly bluer? thanks!
Old Nov 13, 2005 | 10:28 PM
tiguy99's Avatar
tiguy99
The bulbs are exactly the same across the board. Its a matter of optics that makes them appear different. And that my friend comes from HID projectors. Look up the HID bulb bananza sticky for more info
Old Nov 14, 2005 | 08:10 PM
AJL's Avatar
AJL
Registered User
ok..thanks!
Old Jan 31, 2007 | 09:28 PM
David1969's Avatar
David1969
Subscribing
Old Feb 5, 2007 | 08:05 PM
David1969's Avatar
David1969
Total PITA when you have no idea what you're doing...even with pics. But at least the broken bulb has been replaced and all is well....for now.
Old Feb 5, 2007 | 09:25 PM
rominl's Avatar
rominl
exclusive matchup
lol, and i am sure if you do it all over again it will be an easy task
Old Feb 10, 2007 | 03:15 PM
Panerai127's Avatar
Panerai127
Henty, thanks for the info.. I changed HID bubls to philips 4300k and my lights do not auto-level now?! I think I did everything right, any idea? Do I have to reset anything?
Old Feb 10, 2007 | 05:22 PM
Panerai127's Avatar
Panerai127
I think I fixed it.. I took out ECU-B fuse for 25min, then having the lights switch on auto, turned the engine on and saw the lights auto-level, first down, then up..
grrreat suksess!! like Borat would say..
Old Feb 10, 2007 | 09:00 PM
Panerai127's Avatar
Panerai127
I just noticed that my driver's side headlight is lit higher and when I looked from the top down onto the headlamp the bulb shinny housing inside the headlight has a much bigger gap then the passanger, I must have moved it or something when I installed it.. I will try to redo it tomorrow and maybe try to move it back into place.. I hate when something does not go right after I do something to the car..
Old Feb 11, 2007 | 10:33 AM
Panerai127's Avatar
Panerai127
Default HID leveling problem
Ok here is my problem.. Can anyone look at your headlights and compare them to my pics that I included on the bottom of this post.. one of my headlights is not alligned correctly.. after putting the car on straight road, I started the car and saw the lights auto level and these are the pics of the way my lights are leveled, there is a problem and I must re-adjust them, but do not know how!
Driver's side:
Passanger's side:
Old Jun 6, 2007 | 04:03 PM
Adam2562's Avatar
Adam2562
www.autodirectsave.com $85.99 each replacement Philips 4300K bulb.. great buy!!!! just ordered mine... will get them in a few days or so
Och
Lighting
Nov 7, 2010 12:30 AM
Killak9
Jul 18, 2010 09:41 PM
Rockero28
Lighting
Mar 8, 2007 09:30 PM
iceewillie
Jan 8, 2005 03:41 PM
anthracitetarga
Jun 6, 2001 02:50 PM
