FS: SC300/SC400 Big Brake Setup - similar to Supra TT BBK
Former Sponsor
FS: SC300/SC400 Big Brake Setup (used 4 piston calipers - similar to the supra tt upgrade)
Fully loaded with pads, shims, pins.
You will need high disk wheels to clear the calipers. Example: supra tt wheels will clear.
$210 local
$240 shipped
gazi_ali@hotmail.com
Buy with confidence: https://www.clublexus.com/forums/sho...hreadid=119137
You can get more info on this setup and results from here:
https://www.clublexus.com/forums/sho...hreadid=120615
Here is a pic of a caliper which are painted:
Install info for a a second gen GS:
https://www.clublexus.com/forums/sho...d.php?t=144561
$210 local
$240 shipped
Originally Posted by silversprucesc3
Gazi,,, by chance do u know if these will clear the NA supra rims 16 x 8 fronts?? curious as i have installed these for the winter.
D
D
Former Sponsor
rotors not included, u can get them from irotors.com, ebay, or Siniquezu
supra na, wheels will NOT clear, u can use spacers to make them fit, if you do not want to change the rims.
