CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
All New Billet adjustable UCA Upper Control Arm for the ISFs
Old Oct 18, 2021 | 08:16 AM
RRRacing's Avatar
RRRacing
Sponsor
Default All New Billet adjustable UCA Upper Control Arm for the ISFs
RR Racing is introducing a brand new addition to our suspension line! These 100% USA Made Billet control arms are the perfect way to complete your suspension build.
  • Adjustable camber for improvement in front end cornering traction and reduction of outer tire wear,
  • Reduced deflection for improved steering feel and precision, and
  • Optimized caster for maximum camber gain and increased steering weight and stability.
Camber is easy to adjust with two spherical rod ends. Camber can be increased for track days and reduced for street use to improve tire wear. The typical camber adjustment range is approximately -1 up to -3.5 degrees of negative camber, enough for any track application using street or race tires.
Due to the caster offset built into the CNC arms, we build in a maximum caster increase and there is no need to adjust caster. Increasing the amount of caster has several benefits, including improvement of steering effort and straight line stability, particularly at high speeds. Additionally, the more positive caster that is built into your suspension geometry, the more negative camber is gained as your wheels are turned. This allows for a reduction in the amount of static negative camber required, thereby improving inner tire wear and braking performance.
Construction of our Ultimate Upper Control Arms is second to none. Key features are:
  • Made in USA CNC 6061-T6 billet arms exhibit incredible strength and durability under the most demanding conditions.
  • High quality chrome steel spherical rod ends for adjustment.
  • 7000 series aluminum jam nuts (every bit of weight reduction counts!)
  • OEM quality fully sealed no maintenance Japanese ball joint.
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old Oct 18, 2021 | 09:04 AM
Rossi's Avatar
Rossi
To adjust them, you need to remove the tire and remove the control arm itself every time right?
Old Oct 18, 2021 | 11:11 AM
RRRacing's Avatar
RRRacing
Sponsor
Yes, that is correct. But it's not difficult to do. There were ways for us to make it adjustable without removing but it reduces spring clearance and raises costs up.
__________________
Phone: 484-756-1777
Facebook : Youtube
Old Oct 18, 2021 | 01:25 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Looking good!
Old Nov 20, 2021 | 06:20 PM
Rossi's Avatar
Rossi
@RRRacing
Hey Rafi, what can I expect as fas as NVH? Would you say these are a good choice for lowered F on KW V3? Street use only. Thank you.
Old Jul 24, 2022 | 10:05 PM
OMGV8's Avatar
OMGV8
Default Caster increase
Reviving an old thread. But I’m wondering how much maximum caster increase are we talking about here with the positive offset ones? My 2016 GSF after CKS coilover install and slight height drop is in the +5 caster territory. I believe it should be higher (~+8). Having issues with wandering and also strong pull to the right.
Old Jul 24, 2022 | 10:13 PM
RRRacing's Avatar
RRRacing
Sponsor
Originally Posted by OMGV8
Reviving and old thread. But I’m wondering how much maximum caster increase are we talking about here with the positive offset ones? My 2016 GSF after CKS coilover install and slight height drop is in the +5 caster territory. I believe it should be higher (~+8). Having issues with wandering and also strong pull to the right.
I believe most of the cars with our upper control arms are getting about 9 degree caster.
Rafi
__________________
Phone: 484-756-1777
Facebook : Youtube
Old Feb 7, 2024 | 10:24 AM
ISFLATE's Avatar
ISFLATE
2nd gear
Man sorry for dig in this thread this late. I m wondering do these control arms allow positive adjustment. The front wheels on my 2008 isf have some issues that the passenger side wheel is more inside than the driver side, like less than 1 centimeter difference. I took it to a shop and the person said everything is good, no broken no break no missing or loose part. All he can think of is to get control arms for the front wheels to adjust the angle. But I think negative adjustment won't help though.
Old Feb 12, 2024 | 07:56 AM
RRRacing's Avatar
RRRacing
Sponsor
How are you determining there's less than 1 centimeter difference? What are you using to conclude that?
__________________
Phone: 484-756-1777
Facebook : Youtube
Old Feb 25, 2024 | 09:53 PM
ISFLATE's Avatar
ISFLATE
2nd gear
We measured it with a ruler and it was kinda noticeable, anyway sorry for the delayed response I actually went and got ur uca, and the shop was able to adjust that 1 centimeter difference with those uca somehow. Great product! I think I am having noticeably more road feedback, is that one of the features?
Old Feb 26, 2024 | 07:42 AM
RRRacing's Avatar
RRRacing
Sponsor
Yes, definitely. Thse have a little castor built in and are hard mounted with spherical ends which will transmit more feedback. Glad everything was resolved!
__________________
Phone: 484-756-1777
Facebook : Youtube
Old May 18, 2025 | 11:17 AM
Speedin's Avatar
Speedin
Default Knocking noise
I wanted to update anyone interested in installing these control arms. Overall they are very good, but they can have a knocking noise. My noise started just a few months after install. They have been on the vehicle for a couple of years and the noise has not improved. What I have found is the ball joints have no grease at all and are running dry. This is disappointing considering the description on RR's website states: "OEM quality fully sealed no maintenance Japanese ball joint." My very original oem control arms never made noise and for the price point, $0.50 of grease should not be optional. Hard to describe them as oem quality when they do not perform even close to the same due to lack of grease and the loose boots which will likely allow water in. PLEASE do yourself a favor and pull back the "non-serviceable" boots on the ball joints and grease them really well prior to installation.
Old May 18, 2025 | 01:02 PM
RRRacing's Avatar
RRRacing
Sponsor
please DM us a pic of your ball joint if you’ve removed it. We always buy the same part number but we found that rarely the supplier substitutes a very similar ball joint that looks essentially the same but is prone to failure. We have not had failures of the correct ball joint. Now that we are aware of the issue, we are only using the one type that we know works.
Rafi
__________________
Phone: 484-756-1777
Facebook : Youtube
Old May 18, 2025 | 01:25 PM
Speedin's Avatar
Speedin
Rafi
Ill Dm in a couple of weeks as thats the next chance I have to photograph the ball joints. Until then, I did apply a lot of grease in the boots and the corrosion I saw in the ball joints will likely still be there.
RRRacing
Club Lexus Vendor Marketplace
Oct 4, 2021 06:25 PM
JDMV8
IS F (2008-2014)
31
Jul 21, 2021 05:46 AM
cjinthesky
Jun 8, 2021 09:15 AM
RC5
RC F (2015-present)
13
Nov 9, 2018 11:24 AM
92blacktt
Mar 16, 2009 07:37 PM
