button next to OBD port
Old Oct 18, 2017 | 12:54 PM
a1rh3adsz's Avatar
a1rh3adsz
Default button next to OBD port
hey guys quick question. I just notice this, under where the fuse box on the driver side is next to the OBD port what is that button that says "SET" ? and next to it i have a empty slot am i missing something there?
car is a 2014 is350 f sport.
Old Oct 18, 2017 | 12:59 PM
ClubLUser's Avatar
ClubLUser
Do you have TPMS? i think its for setting the low tire PSI range.
Old Oct 18, 2017 | 01:07 PM
a1rh3adsz's Avatar
a1rh3adsz
Yep i have TPMS. i see so pretty much is this how it works? put the amount of psi in the tires then click the set button once it falls below that it would alert you on the dash?
and as for the other slot next to it am i missing something? or its suppose to be blank?
Old Oct 18, 2017 | 01:10 PM
ClubLUser's Avatar
ClubLUser
upload a picture so i can see.
TPMS, hold the button and when it goes under a certain value ( i think its like 10 psi? under what you pushed the button at) there will be a warning.
Old Oct 18, 2017 | 01:20 PM
a1rh3adsz's Avatar
a1rh3adsz
Here is the picture i took
Old Oct 18, 2017 | 01:23 PM
ClubLUser's Avatar
ClubLUser
not sure what that empty spot is, i have it as well.
Old Oct 18, 2017 | 01:27 PM
a1rh3adsz's Avatar
a1rh3adsz
oh, at least its not only me LOL, let see if someone else can confirm that slot. But thank for the reply.
Old Oct 18, 2017 | 02:37 PM
isosunrise's Avatar
isosunrise
Why don’t other cars have this? 2015 is250 f sport
Old Oct 18, 2017 | 02:40 PM
a1rh3adsz's Avatar
a1rh3adsz
Originally Posted by isosunrise
Why don €™t other cars have this? 2015 is250 f sport
are you saying you dont have the "set" button ? Do you have tpms?
Old Oct 18, 2017 | 02:41 PM
isosunrise's Avatar
isosunrise
My bad I just saw it. I’ve been under there a few times and nerve noticed it. Just pressed it a few times nothing happened while driving
Old Oct 18, 2017 | 02:42 PM
Htony's Avatar
Htony
Oh, my, what's next to the button? . The TPMS sign...., LOL! Haven't read or looked up the owner's manual?
Old Oct 18, 2017 | 02:49 PM
a1rh3adsz's Avatar
a1rh3adsz
Isn't the TMPS sign like this (!) most car i seen have that. lol why look up when you can just ask.
Old Oct 18, 2017 | 02:59 PM
heffnerlex's Avatar
heffnerlex
I have no idea what the blank spot is for, but the TPMS "Set" button is used for when rotating the tires according to the owner's manual.
Old Nov 4, 2017 | 04:13 PM
ClubLUser's Avatar
ClubLUser
Found out what the blank spot is...
Adaptive Front Lighting system.
Old Nov 4, 2017 | 05:30 PM
Darqhelmet's Avatar
Darqhelmet
You all found the ejection seat button! Don’t press it. Or read Hefferners post.
