Rear Windows
Old Dec 25, 2022 | 03:37 PM
4litre's Avatar
4litre
Default Rear Windows
My top had to be manually reset and the rear windows didn't come back up. Chances are I'll never use the top anymore and just enjoy her as a coupe. It's what it is. Can someone tell me how I can bring them up?
Old Dec 25, 2022 | 03:56 PM
Gerf's Avatar
Gerf
I thought you had a 460?
Old Dec 25, 2022 | 04:10 PM
4litre's Avatar
4litre
Yup past tense...
Old Dec 25, 2022 | 04:52 PM
Gerf's Avatar
Gerf
Well, never fall in love with any car is my motto haha.
Old Dec 25, 2022 | 04:55 PM
4litre's Avatar
4litre
Pretty much lol! I know the marque to stay with though!
Old Dec 25, 2022 | 10:16 PM
4litre's Avatar
4litre
After searching the web, the answer is here and this is what I'll do...https://www.clublexus.com/forums/sc4...w-mod-diy.html
Old Dec 26, 2022 | 07:56 AM
4litre's Avatar
4litre
Can't do it without relay type the link is old...anyone know?
Old Dec 26, 2022 | 08:10 AM
4litre's Avatar
4litre
submitted twice my error...deleted
Old Dec 26, 2022 | 11:07 AM
Cinc04's Avatar
Cinc04
4litre, maybe I misunderstood your question, but if you are just trying to close the rear quarter windows, here is the procedure:
Turn the ignition switch on
Old Dec 26, 2022 | 11:12 AM
Cinc04's Avatar
Cinc04
I must have hit the wrong button and did a partial post. To start over,
4litre, maybe I misunderstood your question, but if you are just trying to close the rear quarter windows, here is the procedure according to my repair manual:
1. Turn the ignition switch ON
2. Turn the luggage opener main switch from ON to OFF (switch is in glove box)
3. Push the roof opener switch on the OPEN side twice slowly within 10 seconds after step 2.
4. Hold down the same swith on the CLOSE side, keep pressing within 10 seconds after step 3.
Old Dec 26, 2022 | 01:52 PM
4litre's Avatar
4litre
Thanks I've been trying this with no success.
Old Dec 26, 2022 | 05:53 PM
Raven01750's Avatar
Raven01750
You need to run a scan for codes. Unfortunately, the codes for the top only present themselves while the top is in operation. But my guess is you have a bad switch for the top or the top ECU is somehow faulty. Does the top open and close? Anything?
Paul
Old Dec 26, 2022 | 07:42 PM
4litre's Avatar
4litre
Paul
It worked when it opened...that was it. Had to be closed manually and the rear windows didn't roll back up. The switch never blinked or anything even when it opened the roof. I'm just going to wire the windows up with a relay and switch. I'll get a Techstream later.
Old Dec 27, 2022 | 10:13 AM
GmanSC's Avatar
GmanSC
You have the interuption in the closing sequences. For the top to open or close the rear window must roll up or down. The fact that your top opened and the rear window rolled down that tell us the motor is OK. So, most likely it’s the switches at fault. I don’t know if the relays will solve your problem. I’d get the TechStream and find out the causes and fix that. My two cent. Good luck.
Old Dec 27, 2022 | 11:38 AM
4litre's Avatar
4litre
Thanks and you're probably right about that! I'm looking into a tech stream.
