LEXUS SC430 P0325 Engine Knock Sensor
Old Jul 18, 2022 | 11:06 AM
v2daniel's Avatar
v2daniel
10th Gear
Default LEXUS SC430 P0325 Engine Knock Sensor
Hello,
I just recently received a P0325 code, which I understand is a Bank 1 knock sensor. The engine lost much of its power. I took it to a local mechanic who could not hear a knock and suspected that the sensor itself or its harness may be faulty. I went through the hack where I connected the sensor from Bank 2 to the ECU. I used the pinout for the LS430 (which I assumed was the same). However, the check engine light with the same code came back. My concern is that if I have the actual knock sensors replaced, that the issue would still be there (and here in NY this repair seems to be very expensive). I only use premium and also used a fuel injector cleaner, which did not help. Any insight would be appreciated. Thanks!
Old Jul 18, 2022 | 11:35 AM
DshngDaryl's Avatar
DshngDaryl
I am not familiar with the Knock Sensor issue, since it is quite rare in the SC430. I do know @BON and a couple other guys changed theirs.
However an equal number of people thought it was the sensor and found out it wasn't
I would google Clublexus.com sc430 "knock sensor" P0235 and see what other people did to resolve the issue.
Old Jul 20, 2022 | 02:19 PM
v2daniel's Avatar
v2daniel
10th Gear
My mechanic wants to charge me $1,100 to replace the knock sensors, which is difficult to swallow. Is this typical? Is there any way to troubleshoot to make sure it is the knock sensor? Thanks!
Old Jul 20, 2022 | 04:03 PM
gleeson's Avatar
gleeson
it doesn't sound unreasonable to me, but i live in SF bay area and cost of living here is ?!@#$!.
as explained in post #4 of this thread, i dealt with this exact code for quite a long time.
https://www.clublexus.com/forums/sc4...l#post11263959
i paid $1,500, $675 for labor, the rest for parts and taxes. the big labor charge is because the top of the engine (intake manifold) has to come off and is apparently a PITA.
i changed both sensors even though only one was reporting an error. i also changed the starter since it was now accessible and my car has over 275k miles.
also, needed 2 new intake manifold gaskets.
other than timing belt replacement, this has been my biggest expense since i bought the car. no regrets, the car is an absolute joy to drive.
Old Jul 20, 2022 | 04:49 PM
v2daniel's Avatar
v2daniel
10th Gear
Thank you for your insight and sharing your experience. My main concern is that after going through the whole cost of replacing the sensors, the error code will come on again because it was not the culprit. I recently purchased this vehicle under the assumption/hope that these were bulletproof still at 110,000mi.
Old Jul 20, 2022 | 05:12 PM
gleeson's Avatar
gleeson
i think your assumption/hope that these (engines) are bulletproof is still valid and borne out by shared experience here on this forum. i'm no mechanic but i believe the knock sensors are just a part on the engine designed to detect pre-ignition, just as tpms sensors are designed to detect low tire pressure, and seatbelt warning lights remind us to buckle up. a failure of a knock sensor does not reflect on the reliability of the engine imo.
though many people say they never have had a knock sensor go bad, i wonder how may miles they have on their car? you got over 110K miles before your knock sensor went out. imo, that's not so bad. i got almost 274K miles out of my knock sensor. the code has not returned since i had them both changed.
Old Feb 7, 2023 | 09:35 AM
CoonsTuned's Avatar
CoonsTuned
7th Gear
So what was the final verdict? Did you replace the sensors and all is well? Or was something else involved? I'm diagnosing my P0325 now and appreciate any thoughts or experiences shared
Old Feb 7, 2023 | 11:50 AM
v2daniel's Avatar
v2daniel
10th Gear
I ended up replacing the knock sensor(s), which largely took care of the problem. At the same time, I also asked for the spark plugs to be replaced, timing belt, water pump, new engine mount, new air filter, synthetic oil change, and oxygen sensor cleaned. I don't remember exactly how much this cost me, but all this maintenance was well over $2K. I think the quote for the knock sensor was $1000 in NY using Lexus components.
The problem went away and I enjoy driving it, however, it still feels much more sluggish than my 2010 LS460, which I find surprising. My 1999 Boxster with 2 fewer cylinders feels much more quick, but I understand it is not a fair comparison. I hope this helps.
Old Feb 7, 2023 | 04:29 PM
doobs's Avatar
doobs
Have you reset the ECU?
Made a substantial difference on my car.
Old Feb 7, 2023 | 04:52 PM
v2daniel's Avatar
v2daniel
10th Gear
I have not. I did not realize that this could improve things. I will give it a try if it does not upset other systems. Thanks!
Old Feb 8, 2023 | 04:13 PM
Wilson2000's Avatar
Wilson2000
i believe the knock sensors are just a part on the engine designed to detect pre-ignition...a failure of a knock sensor does not reflect on the reliability of the engine imo.
Yes, a knock sensor detects pre-ignition. Once detected, the ECU retards the timing to eliminate the knock. However, if a sensor has failed, as evidenced by the codes, the vehicle won't pass smog. Too, if one inadvertently fills up with regular, and the knock sensors aren't working, then engine damage may result. So, based on these two possibilities, it seems like a reliability issue to me.
Old Feb 10, 2023 | 02:18 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
when you say sluggish, do you mean from a stop?
if so, try this and report back
SC430 Accelerator Reset
1. Get in your car and insert key. (It doesn't matter if you close the door or not.)
2. Turn the key to the on (not start) position.
3. Press the gas pedal to the floor.
4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position
(don't remove the key), then release the gas pedal.
5. Wait 2 minutes.
6. Remove key.
Old Feb 10, 2023 | 08:26 AM
v2daniel's Avatar
v2daniel
10th Gear
Thank you for your guidance! I will give it a try today and let you know whether it worked.
Old Feb 10, 2023 | 11:39 AM
v2daniel's Avatar
v2daniel
10th Gear
5. Wait 2 minutes.
6. Remove key.
I just gave your procedure a try. I believe it worked, as I feel the car is more responsive after a stop. Many thanks for the tip!
Old Jun 12, 2023 | 06:50 AM
JahnBoy's Avatar
JahnBoy
3rd Gear
Default Same same in Italy
Just had the PO325 come on, seems to be intermittent. I recently brought my 02 SC to Italy where I'm living now. If you're not familiar with the area, the roads are some of the worst I've experienced, and on the run flats I've failed to change it's a harsh harsh ride. My question is if anyone has experienced bad connections and if the roads were an issue? I'll jump into troubleshooting shortly. At first I was afraid i was getting crappy fuel but it turns out I've been running 95 or even 98 from a reliable brand here...
