Programming the garage opener
Thank you Poqman.
Liftmaster 855LM HomeLink Repeater Kit.
Where can I get it?
Checking homelink.com, it says we need a HomeLink Compatibility Bridge Kit.
Is it similar to Liftmaster 855LM HomeLink Repeater Kit that you mentioned?
Here's the procedure:
INSTALL AND PROGRAM THE HOMELINK® COMPATIBILITY BRIDGE
1.Program the HomeLink in your vehicle using the new remote control included in the HomeLink Compatibility Bridge Kit in place of your original garage door remote control. Refer to your vehicle’s owner’s manual for programming steps.
2.Plug the HomeLink Compatibility Bridge into a 120 vAC polarized outlet, located as close as possible to your garage door opener.
3.Straighten the antenna
4.Press and release the YELLOW “Learn” button on the garage door opener. The “Learn” LED will glow steadily.
5.Within 30 seconds press and hold the programmed HomeLink button in your vehicle.
6.Release the HomeLink button when the garage door opener light blinks. If light bulbs are not installed in the garage door opener, two clicks will be heard.
7.Press and hold the programmed HomeLink button for 2 seconds, three times. Your door should now be operational.
Where can I get it?
Happy to report that both SC430 and LS460 are programmed with the garage door opener today.
The SC was fairly easy but the LS took a bit more work.
Patient is the virtue here.
Homelink and Lexus need to be aware of this.
Especially Lexus Dealer's Service Advisors.
They have no knowledge of this repeater and immediately passing the buck to Homelink.
It's hard to get a person alive from Homelink.
https://www.amazon.com/LiftMaster-85.../dp/B01GWD4LUI
http://www.chamberlain.com/homelink/...ibility-bridge
for what it's worth, I installed this about two yrs ago and it worked great with my older home link units.
here is a link to home link, where you can look up your car and the door operator you have or want.
Alright, lemme try this repeater - I tried about 6 times on my brand new garage door opener and it failed. The SC never had an issue with 10 year old garage door units. Just these new ones. Hope this works out. Will report back after my repeater arrives.
just take your time and it should work the first time. Also, keep the repeater remote and instructions in a place where you will find it in the future, LoL
trust me on that one! ;-)
Alright reporting back as promised - it worked but there is a quirk to it. Managed to program 2 garage doors into the left and middle button respectively. Getting the buttons to accept the signal from the repeater unit special remote was easy - just like in the instructions cos I ensured a brand new battery was in the repeater remote. First garage door was a cinch - everything like what it said in the instructions - I had a learn button next to the door opener switch so did not need to climb up to the opener itself to activate the learn function - done in 30 secs. Second garage door was harder - used the learn button next to the garage door opener wall switch and the car just would not sync with the second garage door opener. Finally, climbed up a ladder, hit the learn button on the second opener that is located on the back of the unit itself and homelink button two in the SC synced on the second try. So finally a happy camper.
BTW for my other cars ( 2010 onwards Acura/Benz) I never had the same issue with the second garage door opener. The learn button next to the wall switch worked to sync the cars buttons. Never had to climb up to hit the button on the door opener itself.
Anyway, glad it all worked out - so yes the homelink repeater thing is the answer. Bought on Ebay -$25.
I was having a similar problem in getting it to work.
I was pressing the hand-held remote every 2 seconds as recommended in the manual.
When I tried pressing the "learn" button instead on the roof mounted console it finally worked.
You actually have to hold down the Homelink button for about 2 seconds for the garage door to start working.
Cheers, Nick
Cheers, Nick
That is the same problem that I had while trying to program the HomeLink. I would go through the learning steps and it would not open the garage door. Finally I got mad and held the HomeLink button down for a couple of seconds and the door opened! It does not work as fast as the door opener remote!
harmonytom
Apr 1, 2014 03:57 AM
mamono
Jul 29, 2008 08:17 AM
