Hub Centric Rings
Old Jan 28, 2022 | 03:16 PM
SrWilliams's Avatar
SrWilliams
Default Hub Centric Rings
Hello everyone:
Since I have aftermarket rims accompanied by a shake in driving I did a lot of research and realized that I need hub centric rings. I know in order to get the proper size of the rings I need to measure the outer diameter of the SC 430s wheel hub and the inner diameter of the aftermarket wheel hub opening .
Can someone let me know the outer diameter of our wheel hubs. I measured them at 2 1/2 inches needing to convert that over to millimeters. But I want to make sure I did this correct.
If anyone has the more exact measurement of the hub please chime in and provide assistance
Thanks
Old Jan 28, 2022 | 03:54 PM
digitatc's Avatar
digitatc
You'll need a set of 72.6mm to 60.1mm or 73.1 to 60.1mm hub centric rings
60.1mm is for the Lexus. Most aftermarket wheels have 72.6mm or 73.1mm, double check yours though.
Old Jan 28, 2022 | 06:27 PM
SrWilliams's Avatar
SrWilliams
Digitatc:
Thank you so much for the quick reply and helping hand. I went to the shelves and dug out my battery operated diameter measure (whatever it is called) and you are so right. the hub diameter is 60.1mm and the aftermarket rims are 73.1mm.
Was getting ready to make a big mistake and your guidance saved me.
Again thanks and I just ordered the right rings
C
Old Jan 30, 2022 | 05:23 PM
mostrogt3's Avatar
mostrogt3
You can find a set of four on Ebay. I have used these before for other applications and I just bought a set today for some Niche wheels I picked up yesterday locally on Offer Up.
Niche use a 72.6mm so I got rings from that to 60.1.
Wheels should be on I say in s week or so since I want to test fit and see if I need any spacers plus I will evaluate what direction I want to take on the suspensio...springs or coilovers.
czr73
Feb 18, 2014 09:08 PM
BIGMerle
Wheels, Tires & Brakes Forum
Sep 27, 2010 03:04 PM
stephencd1
Aug 23, 2009 01:49 PM
GS300ToM
May 16, 2009 04:21 PM
topman
Apr 23, 2008 01:06 PM
