Navigation screen replacement
My navigation screen is faint and monochromatic. Replacement is needed. I have found two listings for what I think is the correct part number. One is double the cost. I am trying to make sure they are the same and will work with the car. On the lower cost one, on the number sticker in the upper right, the last 3 digits are 112. The same sticker in the higher priced unit ends in 111. With all the wisdom here, will these units work? Would I be better off with something els that is updated for CarPlay for a comparable price?
Thanks.
Thanks.
WtSpyder, I'd go with a fast Android with sufficient storage like my Carlaoer. It's an overwhelmingly superior and modern solution, but more work to install than swapping in an OEM display.
If you really want to stay with the stock Nav system, check your PM's.
