Disable Antenna
Old Jul 28, 2020 | 08:48 PM
jmjsc430's Avatar
jmjsc430
Default Disable Antenna
I replaced my stock radio with a Pioneer head unit. I am wondering if anyone has added a switch to power on/off the antenna manually. Apparently it stays up whether the the radio is on or off.This presents a problem at car washes. Ideally, I would like to tap into a power wire from someplace that I will not have to take the head unit out again. Any ideas?
Old Jul 28, 2020 | 11:41 PM
GmanSC's Avatar
GmanSC
You can disconnect it from the trunk but the antenna will not go up again. Do you want that?
Old Jul 29, 2020 | 06:33 AM
jmjsc430's Avatar
jmjsc430
No, I need it to work. Ideally I'd like to tap in to a power wire near the glove box so I can locate a switch inside the glove box. So I guess the question is really this; How do I locate a power wire to the antenna. Is there one near the fuse box perhaps? Again, I am trying to avoid removing the head unit.
Old Jul 29, 2020 | 08:00 AM
NEWONE1's Avatar
NEWONE1
There should be a power antenna wire off the Pioneer head unit wiring harness that you can tap into with an on/off flip switch
Old Jul 29, 2020 | 11:46 AM
Harold57's Avatar
Harold57
IIRC, the pinout of that connector is shown in the "Poor Mans Audio" thread.
Old Jul 30, 2020 | 10:26 AM
Neil E's Avatar
Neil E
Yes, the blue antenna remote wire is the one to use. It's at the back of the head unit but with practice, the head unit is easily removed in a matter of a few minutes. .
http://www.beatsonicusa.com/Instruct...manual_NEW.pdf
Helogadget
Jun 21, 2015 04:08 AM
parijss
Apr 28, 2014 01:54 AM
Arthurt
Oct 27, 2011 09:00 AM
icey white
May 25, 2006 06:22 AM
Whitmanpc1
Jul 21, 2001 06:19 AM
