O2 sensor harness wire colors
One is a ground and the other is another wire for the heater element.
So is W a ground?
Or is BR a ground?
Paul
I’ll have to get a pic later as my wife has the car right now. But regardless, it’s wired “correctly” based on all the info here.
I do appreciate all the help guys, I just don’t understand how this is creating such an issue.
And on top of it all, the last guy cut all the engine harness wires so short that to redo his wiring mess it all had to be done in the little space between the firewall and the back of the engine.
This sounds extreme. But I would find a replacement harness on ebay or you may have issues like this for years.
Paul
Paul
Paul
Also have a new o2 sensor in the mail so we’ll see if the current one is bad.
The o2 I pulled off the car the other day looked to be almost new so that one may still be good too if this wiring nonsense was the issue.
Bgw, I haven’t tested any of them... lost my meter a while back and never got around to a new one. I know, I know.
I wonder if driving a few miles for the test drive with the sensor wired in assbackwards was able to damage the sensor.
2 1
4 3
This matches the diagram on the third photo as well (and also matches my 2008 book).
In my book, you check the heater across pins 1 and 2 (both black wires on the Denso O2 sensor).
From what I can gather looking at the thread and photos above, and going by the O2 sensor connector pin numbering above (in this message) your wiring should be:
1 HT (heater ground via the ECM)
2 +B (heater positive)
3 OX (shielded control wire going to ECM)
4 E1 (non-shielded control wire going to ECM)
