OEM Airbox Mod
Old Oct 26, 2020 | 09:28 PM
  #31
joemg's Avatar
joemg
Originally Posted by digitatc
It's not the same. He just want to tell us that he did break all the fins from the SC430 box to make it like the IS F sport airbox.
Smooth > more intake noise.
I think the fins are there to reduce the noise.
Now I'm seriously considering grabbing the dremel and going to town on them. I find it interesting that Lexus went through the trouble of changing the airbox for the Fsport.
Old Oct 26, 2020 | 09:49 PM
  #32
digitatc's Avatar
digitatc
Cut a hole in the front as well.
Old Oct 27, 2020 | 02:07 PM
  #33
joemg's Avatar
joemg
LOL, fine!
question, what did you all use to get rid of the fins exactly? any particular technique? I have my airbox out now and I'm trying to figure out the best way to attack it.
Old Oct 27, 2020 | 02:20 PM
  #34
evgeniy's Avatar
evgeniy
Originally Posted by joemg
LOL, fine!
I cuted the hole like isf and broken rid by pliers.
Old Oct 27, 2020 | 02:53 PM
  #35
joemg's Avatar
joemg
Hah, thats funny, i just put down the dremel and grabbed the pliers... looks like i'm on the right track.
cutting the hole was the easy part
Old Oct 27, 2020 | 03:48 PM
  #36
digitatc's Avatar
digitatc
If you have access to an Oscillating tool like this, then it'll help.
Old Oct 27, 2020 | 04:02 PM
  #37
joemg's Avatar
joemg
I actually don't own one of those (though I'm really wishing I did)... I've gotten most of the fins off with pliers, but now i need to smooth it all out. Fair warning to anyone considering this, this is a giant pain in the ***, lol.
I'm kind of wishing I just cut the hole and called it a day, but there's no going back now.
Old Oct 28, 2020 | 09:37 AM
  #38
joemg's Avatar
joemg
a dremel is 100% the wrong tool for this job.
How smooth was the inside of the box when you were done? mine is really rough and I can probably get it smoother with a lot of sanding, just curious how much it matters.
Old Oct 28, 2020 | 10:50 AM
  #39
joemg's Avatar
joemg
Here's what I've got so far.
I did the top and the bottom, fins are gone, I did some light sanding to smooth it out, it would need a LOT more to be very smooth.
Going to do some more sanding in a bit.
Attached Thumbnails OEM Airbox Mod-img_8248.jpeg   OEM Airbox Mod-img_8249.jpeg   OEM Airbox Mod-img_8250.jpeg
Old Oct 28, 2020 | 02:50 PM
  #40
joemg's Avatar
joemg
ok, I got it to where it wasn't rough to the touch with 1000grit sandpaper and called it a day. Put it all back together and went for a drive.
It does sound a pinch louder which is nice, though not an overwhelming difference.
The other interesting thing is intake temps actually dropped from about 15-20 above ambient average, to about 5-10. At times even being the same or within a degree or 2 of ambient on the highway.
This could be because I replaced the torn up weather stripping between the airbox and the scoop which may have been letting warm air into the scoop. Either that or the oem scoop picks up slightly warmer air than the air coming through the headlight opening into the new hole.
I didn't bother running any piping from the new hole (2.5" round) and there doesn't seem to be any reason to after my testing.
Old Mar 28, 2025 | 01:42 PM
  #41
joemg's Avatar
joemg
I decided to put a grill in the 2.5" hole since I didn't pipe it. Just to keep anything big/small animals out of the airbox. I was going to use some RTV around the edge, but it fit so snuggly in place I didn't bother. I aimed the louvers to pull from the bottom.
It looks nicer than just a 2.5" hole in the front of the airbox. I'll snap a pic next time I pop the hood.
Amazon Amazon
Makillaz
Mar 28, 2016 02:50 PM
brociouz
Dec 24, 2010 09:53 AM
ndk83
Performance
Nov 28, 2008 08:56 PM
The Ikon
Nov 26, 2001 07:50 AM
