Car does not rev over 3000 rpm
Hello everyone
My name is Ossy
My 2008 lexus SC430 rev’s up to 3000rpm and the engine will start shaking and it not go beyond 3000rpm. Please anyone know what could be the problem
My name is Ossy
how many miles?
ever change the timing belt, water pump etc, if so when?
is the check engine light on?
We need more infos. Take the car to the mechanic. They should be able to tell you what is your problem, then come back here, we might be able too help you to fix it.
It sounds like one of your computers are unhappy.
I would disconnect your battery for 10 minutes and reconnect it.
If I were to make a wild guess, I would say possibly your transmission is in LIMP MODE. That is a mode which will allow you to drive your car to a mechanic, but not let you get out of 2nd gear.
Or possibly, your transmission is having such a big problem, it won't let you get out of first gear.
10025 SW Freeway 77074
Thursday 27th December
7:00 am
Keven Rep
Do Complete diagnostic on the entire car
My lexus rev over 3000rpm and the engine will start shaking (check)
Car does not ride smoothly (check)
Climate control system (check)
If anything is wrong with the car
Hello everyone
My name is Ossy
Thanks guys
Ok
I bought the car and lost the timing belt one month after, car had about 112,000 miles on it when I bought it. The timing belt and the sub head one side was replaced and since after that I have been having that problem.
The mechanic told me it was the air flow meter and we replaced it and it didn’t solve the problem. Now he is telling me it is the ECU. Not sure what to believe anymore I started looking elsewhere and I found you guys. Really appreciate the response to my concern
7:00 am
Keven Rep
Hello everyone
My name is Ossy
Lexus. Address
7:00 am
Keven Rep
Hello everyone
My name is Ossy
Thanks guys
Ok
Note: please I am still trying to figure out how to use this site bear with me if I am not posting properly. Thanks
Thanks guys
Ok
First, you need to learn how to post. Your post is confused the heck out of me (us). Second, you said you lost the timing belt, what's happened? Was the belt snap broken? Was the engine damage?
I think your problem is related to the timing belt, its timing could be off, your cylinders are miss-fired. Do you have Techstream or know someone has Techstream? With Techstream, it could point you to the right direction.
Good luck.
Good luck.
Give the guy a break! He just joined ClubLexus, so if his post are a little confusing, ask clarifying questions. Don't flame him.
The one thing everyone says about this forum is that it is civil. Don't ruin it now by jumping on people.
Ossy,
Can you answer these questions to help us understand your situation better?
Does you car drive? Does it drive, but the engine shakes when you get over 3000 RPM?
Has your car ever driven properly since you owned it? Or did you buy it that way?
After the timing belt break, what have you tried other than the air flow meter?
Gman is right about having the codes. Did the dealer or your mechanic give you any trouble codes? They would most likely start with a P and have 4 numbers following them.
I am trying to figure out how the site works.
Is there any instructions on what button to push to post, and then follow the treads as I was just trying to see what works.
To me the SC430 is one of the most beautiful classy cars I have ever seen and I would think that anyone who appreciates the classiness of this cars has some as well because it deserves it.
Ultimately we are all here to help each other because of our common interest. I would accept private message from any one to guide me on how to post.
Once again I didn’t mean to offend anyone and if I did I am sorry. I hope this posting comes out right
Your post came out good. Now can you tell us more about your problem? We’re here to help.
I bought the car and the mechanic opened it and found out the timing belt snapped and broke, Engine damaged: The following items was replaced,
...Timing belt. Replaced
...Engine Head (one side) Replaced
...Radiator and hoses Replaced
... Pistons Replaced
... Ring sets. Replaced
...Gaskets. Replaced
Car had about 112,000 miles on it when I bought it.
After all the repairs was done the car runs and drives fine but would start shaking violently once it reaches 3000 RPM. This happened while it was idling or driven. At this time the mechanic thought it could be the Air Flow meter and that was replaced too but it did not resolve the issue.
The mechanic is telling me now he thinks it is the ECU. Not sure what to believe anymore I started looking elsewhere and I found you guys. Really appreciate the response to my concern
Ossy,
I'm so sorry this happened to you. Now we understand your problem. Let me ask you:
1. When did the job was done? Was it done by licensed mechanic?
2. Do you have any written warranty?
3. How about the valves? Did they get replaced?
It sound little funky to me because if the job was done by licensed mechanic, he must warranty his work. If he was good mechanic, he should have a code reader or diagnosis software to pinpoint the problem area.
Unless, your mechanic is unlicensed, I would pressure him to fix the problem or take him to court.
I'm not a mechanic so I can't help you much but others on this board can. I still lthink it has something to do with the timing belt. For the mean time, you can disconnect the battery, let it sit for good hour or so, hopefully it will reset the ECUs.
BGW, VitiBob, Cold, Shawn, Johnny what do you guys think?
