Kaaz lsd uzz40 dat3020?
Old Oct 17, 2017 | 12:08 AM
Alokat007's Avatar
Alokat007
Default Kaaz lsd uzz40 dat3020?
I came across this LSD Differential, it says compatible with UZZ40
APPLICATION 6:
Make - Lexus
Model - Soarer
Series - UZZ40
Year - August 1996 - April 2003
SC430 Chassis is UZZ40
Does anyone know if this will fit in SC430 Pumpkin?
Old Oct 18, 2017 | 11:00 AM
DshngDaryl's Avatar
DshngDaryl
https://en.wikipedia.org/wiki/Toyota_Soarer
Old Oct 24, 2017 | 02:58 PM
Alokat007's Avatar
Alokat007
An update for this
I e-mailed Kaaz about their LSD if it will fit SC430 and this is their respond:
Hi,
Thank you for your inquiry.
The part number DAT3020 will only fit the UZZ40 until about April '03 production.
Sometime in 2003, Toyota made a change in the rear differential casing
design. The older unit had a cutout on the casing to allow our lsd to fit.
The newer casing does not have this cutout so our unit will not fit.
I don't think the newer SC430 have this cutout.
Please see the attached photo showing the cutout and not cutout.
The only way to fit our unit to the newer vehicle will be to swap out
the rear differential casing to the older style.
Best Regards,
Ray Nakadate
Kaaz USA
Also Kaaz attached two photos for explaning:
First photo no cut out from 2004 - 2010.
Second photo with the cut out for 2002 - 2003, The ones will fit.
So the only way to fit Kaaz LSD 2 way by buying 2002 or 2003 pumpkin.
Attached Thumbnails Kaaz lsd uzz40 dat3020?-no-cut-out.png   Kaaz lsd uzz40 dat3020?-with-cut-out.png
Old Oct 25, 2017 | 03:13 AM
gerrb's Avatar
gerrb
Super Moderator
You can use the 98-2000 LS400 , JDM MKIV 6speed TT pumpkins too .. they will have same 3.26 gear ratio and bolt in to the SC430 subframe.
Not all Soarer pumpkins will have same 3.26 gear ratio as that of our SC430 .
Old Oct 25, 2017 | 11:34 AM
Alokat007's Avatar
Alokat007
Thank you for the input but LS400 1995-2000 "Chassis code UCF20" does not support Kaaz LSD, so even if it fits you can't install Kaaz LSD.
SC300 and SC400 both fit Kaaz LSD, ratio 4.11 - 3.91, but i don't know if they can fit in SC430.
According to this thread, it seems 2002 is only one that different from the rest "2003-2005".
To narrow it down to 2003 i guess.
Pearlpower
Apr 27, 2020 12:18 PM
DiverseIS
Jul 1, 2019 07:44 AM
riotgs300
Feb 25, 2015 05:24 AM
clubaddict
Aug 25, 2005 05:39 AM
