2017 RX 350 wheels on SC430
Old May 13, 2017 | 11:06 AM
KingReyes's Avatar
KingReyes
There's also this.
18x8
Old May 13, 2017 | 11:07 AM
Coleroad's Avatar
Coleroad
Originally Posted by KingReyes
Product Number W74252S
Brand Factory OEM
Material Aluminum
Size 19" x 7.5"
Diameter 19"
Width 7.5"
Lugs 5
Bolt Pattern 114.3mm
Offset 35mm
Style 7 Spoke
Part Number 4261A0E010, 4261A0E020, 4261A0E030, 4261A0E040
Finish Silver
Year 2010
Make Lexus
Model RX350
SKU W74252S-4
the op's wheels are a little different than these. They are close, but not the same.
Old May 13, 2017 | 11:10 AM
ShawnOk's Avatar
ShawnOk
So I did a lot of background research on spacers before purchasing a set of Akata/Vossen 30mm BOLT-ON Hubcentric Black Anodized Spacers for my rears. I drive my SC430 pretty hard and fast, pretty often. I had those spacers mounted for about two years before ordering new deeper rims. The spacers added a more aggressive look, and more rear traction (negligible/debatable). They never gave me a problem. With that being said, they were BOLT-ON. I've heard nightmares about slide-on spacers, particularly if the owner does not choose to buy/use longer lug studs. This of course depends on the depth of the spacer. Will 10mm slide on spacers cause the studs to shear? Hopefully not. Although as the video below explains, since they are not hubcentric there's more force on the studs. Anyway, just something to think about if anyone stumbles onto this post and is thinking of going with deeper spacers. My recommendation, if available in the size you need, go with bolt-on hubcentric rather than slide-on spacers. Also, I recommend using antiseeze on all lug threads when possible, and of course. torque all lugs to spec. Oh and I guess lug nuts too, check out second video.
https://www.youtube.com/watch?v=FUY6_enU9eQ
https://www.youtube.com/watch?v=BoDtaoPr6ok
Old May 14, 2017 | 12:15 PM
Chaditotx's Avatar
Chaditotx
Got clearance issue fixed. Countoured the caliper bracket with a dremel flapper wheel. Probably about 2mm on two very small spots. Was planning on smoothing them (casting pits etc) before painting them anyway.
Old May 14, 2017 | 09:05 PM
texsexlex's Avatar
texsexlex
...hey Chad what part of Texas are you located ?....
jackhutson
Apr 15, 2018 11:28 PM
jditom
Sep 8, 2008 07:08 AM
