Throttle responance ???
Old Apr 27, 2016 | 05:57 AM
ruger's Avatar
ruger
Default Throttle responance ???
Im a new owner of a low mile 2004 sc430..My question is there a adjustment for the throttle control as
there seems to be some play in the foot feed before any gas or motion is had...Please reply..
Old Apr 27, 2016 | 08:11 AM
ShawnOk's Avatar
ShawnOk
Search the forum for "Trans Pressure Mod." Best investment I've ever made for benefit in terms of speed upgrade for the SC.
Old Apr 28, 2016 | 11:30 AM
texsexlex's Avatar
texsexlex
...also some say do the disconnect battery trick , to clear the ECU. It has learned the previous owners driving style & clearing the ECU will help it learn your driving habits. These cars with factory settings, will always have a lag to them, some worse than others. The Trans Pressure Mod that ShawnOk mentioned is a big help & also the Sprint Booster
Old Apr 29, 2016 | 03:38 AM
ruger's Avatar
ruger
Can you give nw some info on the trans mod? Is it a kit,or a adjustment, or just what is in involved
Does it put due stress on the trans? please reply.
Old Apr 29, 2016 | 06:11 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Try searching and always use these words first, SC430, then what you are looking for...I used the following,
SC430 Trans mod, and found this,
https://www.clublexus.com/forums/sc4...0-a-650-e.html
Old Apr 29, 2016 | 09:01 AM
ShawnOk's Avatar
ShawnOk
Yes BGW is correct. Use those specific terms when searching for the Trans Pressure Mod. or even google with "SC430 Trans Pressure Mod Club Lexus." The link that BGW has posted is quite informative but there are others on this forum. Check them out and if you have any questions, pose them in those specific threads and we will respond as best we can. Good luck.
DENNISLOGA
Jun 18, 2012 12:45 PM
digger08
IS F (2008-2014)
23
Sep 13, 2011 04:45 PM
jeremysc40
Aug 29, 2011 05:41 PM
SC30096
Oct 21, 2007 11:16 AM
sexlex
Mar 22, 2006 04:51 PM
