Acceleration Issue? Any thoughts..
Old Jan 9, 2016 | 05:25 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Yep, that's what I was trying to say back in post 2...
Old Jan 9, 2016 | 05:26 PM
Harold57's Avatar
Harold57
Yes Coleroad, I agree. One would think that a car like the SC430 that is supposed to be sporty would not have grandma programming in it. But it is what it is...
Old Jan 9, 2016 | 06:11 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Harold, you are so correct in what you were saying!!!
texsexlex's Avatar
texsexlex
...we have to remember, who this car was targeted for when it was introduced...lol
Old Jan 10, 2016 | 08:13 AM
Harold57's Avatar
Harold57
If only they had asked us first!
Old Jan 10, 2016 | 02:15 PM
throw's Avatar
throw
thank you to everyone who has responded. I will get to work asap on all the suggestions. And report back...James
Old Jan 11, 2016 | 06:15 PM
Jaggernaut's Avatar
Jaggernaut
So, The answer to the lag is reset your ECU? Anyone know an aftermarket ECU that could work and be replaced with this ECU? Sorry, I'm new to the car game.
Old Jan 11, 2016 | 06:47 PM
Coleroad's Avatar
Coleroad
Glad that was it. Just drive it like you stole it more often. Lol
Old Jan 12, 2016 | 11:50 AM
Harold57's Avatar
Harold57
I'm not aware of any nor do I remember anyone writing about it on the forum.
Old Jan 12, 2016 | 12:13 PM
Jaggernaut's Avatar
Jaggernaut
Understood...
Old Jan 12, 2016 | 12:25 PM
Retroplay's Avatar
Retroplay
I concur with Harold's recommendations. I brought up the same question a while ago and Harold recommended the door/key/pedal sequence to me and it did help. For a while at least.
I am planning to do the transmission valve pressure mod this spring/summer and I have been trying hard to study what I can to figure out if it is possible to just turn off this silly learning feature. It saves on gas, definitely, but it is a bit embarrassing when you try to go and the car just lags.
Old Jan 12, 2016 | 03:39 PM
Harold57's Avatar
Harold57
Yes, unfortunately, after the reset the ECU starts over its granny adjustments.
If you could find a way to put that de-acceleration beast beast to rest, you'd be enshrined in the SC430 Hall of Fame just on that one accomplishment! The first time I experienced it, I realized that it is not only annoying but dangerous. If I have to accelerate out of a bad situation on the highway or street and the ECU decides otherwise, it could easily become crunch time, if you know what I mean.
Old Jan 12, 2016 | 03:42 PM
Jaggernaut's Avatar
Jaggernaut
Wouldn't an ECU replacement fix this issue?
EDIT: Considering, if you could find a suitable replacement.
Old Jan 12, 2016 | 03:48 PM
Harold57's Avatar
Harold57
The problem is that "if" in your statement. No one has found a suitable replacement yet.
Old Jan 12, 2016 | 03:53 PM
Coleroad's Avatar
Coleroad
The new ECU would do the same thing. The ECU learns how you drive the optimizes shift points, downshift points. It just seems as though the sc430 takes this to a bit more of an extreme. Like I had said, I have seen and heard this on other cars. I wouldn't have explained it as bogging down. More as lazy, not down shifting till wide open throttle. Shifting early, so as causing slower acceleration. A new ECU will just do the same leaning process. The only answer is yo reset it if it becomes this way, or drive it harder sometimes to change the learning process. Hence my half joking comment about needing to drive it like you stole it more often.
