O2 sensor question
Old May 5, 2015 | 03:58 PM
LEXZILLA's Avatar
LEXZILLA
Default O2 sensor question
I just had a bank one O2 sensor replaced on my 03 sc430
And my check engine light and my vac light is still on
I had the car scanned and it says I have a problem with the same sensor I just replaced
Could the sensor be unplugged codes are po133& po 136
Thanks
Old May 5, 2015 | 04:02 PM
texsexlex's Avatar
texsexlex
Thanks
...could it be possible that they didn't clear the code ?
Old May 5, 2015 | 06:04 PM
LEXZILLA's Avatar
LEXZILLA
the mechanic supposedly cleared the codes when the sensor was installed but soon as i drove off
the check engine light and vsc lights came back on!
and i tried the diy with the wire and the pins on the dianostic port!
the lights stayed off for a moment and came back on!
thanks in advance
Old May 5, 2015 | 06:47 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
thanks in advance
Just to be clear, did you short pins 4&14? When you short them, you should see the VSC light flash very fast.
Old May 5, 2015 | 07:29 PM
LEXZILLA's Avatar
LEXZILLA
i think i did because when i started the car those lights were off!!!
i went about a quarter of a mile the my check engine light came on followed by the vsc lights!!!
thanks in advance for any advice the club can give me!
Old May 5, 2015 | 07:48 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
The lights always go off when you turn the key off then restart the engine...the will still be off, now put it in gear, after a few feet, the lights come back on...if this is happening then you should try pins 4&14 again. Just to make sure you did the correct pins...when the wire is shorted, make sure the VSC light flashes fast...
Report your findings to us.
Old May 5, 2015 | 09:43 PM
thombiz's Avatar
thombiz
My experience is with Toyota's and I've not had this problem with Lexus's, nonetheless, on Toyota's I've found that a bad air/fuel sensor can trigger an O2 sensor light. For this reason, I've always replaced all O2 and all air/fuel sensor at the same time. Every single time, this has corrected the problem. I do the work myself and it takes about 1.5 hours to replace all 4 sensors. The parts usually cost me around $350. YMMV.
Old May 6, 2015 | 06:06 PM
LEXZILLA's Avatar
LEXZILLA
i just tried the jumper pin thing the vsc light blinked fast waited 25 seconds waiting letting the car settle restarted the car and the lights came back on i didnt even drive the car!!!!
Old May 6, 2015 | 06:26 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Do you have a code reader/checker? If si, check for codes, if not I believe you need to hookup a jumper on pins 13&4, I believe. There should be a thread on how to pull the codes. It will make a light on the dash blink pause and blink a certain amount of times, giving you a two digit number of times.
Old May 6, 2015 | 07:07 PM
OBP's Avatar
OBP
Thanks
I had a similar experience when the dealer replaced one of my O2 sensors. The VSC and CEL came back on. Dealer later admitted that they broke one of the wires when replacing the O2 sensor and had to fix the wires.
I forget what the codes were for the second go round.
Old May 7, 2015 | 01:50 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
I found this in a Mercedes Benz forum, he is referring to the p0133 and p0136 codes...
Problem solved.
I rechecked everything and found super small exhaust leak. It was a hairline crack in the first, upstream CAT on the weld where cone is attached to the cylinder. Crack was so small that at low idle leak was only detectably when CAT was still cold. It is hard to belive system is so sensitive. After welding and several drive cycle (system goes through some kind of adjustment for the first 3-5 drive cycles) the codes did not showed up anymore.
Similar problem and solution were posted by Benz97 on 10/22/09.
Old May 7, 2015 | 02:00 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
I just saw another post about a Hyundai having an exhaust leak that was causing the code.
Could the new O2 sensor Be defective?
Google these codes...also, I believe the code is p0133 not po133
A Volvo driver said the codes went away after he drove the car for a week, 400 miles. He thought the ECU adjusted to the new O2 sensors.
Old May 7, 2015 | 09:44 AM
LEXZILLA's Avatar
LEXZILLA
Don't think I have an exhaust leak
But I have a smell coming from my exhaust!
I'll check the sensor wires to see if they're broken
Old May 7, 2015 | 01:46 PM
LEXZILLA's Avatar
LEXZILLA
ok ill try the jumper pin thing again!
what pins do i jump?
3&14 or 4&14
any pictures? and step by step instructions
please
Old May 7, 2015 | 03:00 PM
hlthlnk's Avatar
hlthlnk
I have a 2002 sc430 had the same code, bought the o2 sensor from advanced auto, installed it myself, reset the code with their borrowed reader, turned on the car and BAM...code again. After reading some posts, I realized that it could be the same sensor, they are sometimes defective. Went back to advanced auto told them my situation and they did an exchange, the new one worked like a charm! Good luck
