Puddle Light Install
Subscribe
Aug 21, 2014 | 09:22 PM
I just recieved my puddle lights but decided to finally do my 06+ tails today since I got them in aswell. Ill be planjing on doibg them this weekend. I can wire them and do the cut outs perfect but are there any tips on removing the rockers??
Reply 0
Aug 21, 2014 | 09:45 PM
Quote: I just recieved my puddle lights but decided to finally do my 06+ tails today since I got them in aswell. Ill be planjing on doibg them this weekend. I can wire them and do the cut outs perfect but are there any tips on removing the rockers??
... it's not too bad of a job. I removed the rear tire, because there is a bolt at the rear of the rocker & this will make access much easier. You can turn the front wheel to access the bolt up front. There are 4/5 screws along the doorsill inside the car. I can't remember how many push tabs/buttons are under the bottom, but a floorjack will make that job easier also.i think i replaced both of mine,in about 1.5 hours...hope this helps some
Reply 0
Aug 22, 2014 | 08:27 AM
Quote: ... it's not too bad of a job. I removed the rear tire, because there is a bolt at the rear of the rocker & this will make access much easier. You can turn the front wheel to access the bolt up front. There are 4/5 screws along the doorsill inside the car. I can't remember how many push tabs/buttons are under the bottom, but a floorjack will make that job easier also.i think i replaced both of mine,in about 1.5 hours...hope this helps some
Thanks for the tips! Will most likely get on this today or tomorrow.
Miguel
Reply 0
Subscribe
