downstream oxygen sensor replacement
Old May 5, 2013 | 05:41 AM
fj40ih8mud's Avatar
fj40ih8mud
Default downstream oxygen sensor replacement
Just wanted to post up for anyone to see the brillance of toyota engineering. Now I am a huge fan of Toyota, but this is silly. We are talking about toyota sc430 downstream o2 sensor. Mine was showing a fault code, so was time to swap.
Looking at the manual, it does not help much, so i went out and pulled at the wire that passes through under the car inside the cabin under the carpet. Came back into CL and did research, sure enough the connection is inside the console.
Well, to get to the sensor, you have to pull the center console then. So, you pull out the center console, still no wiring harness. Then pull the radio and the climate control. Then the under steering wheel and glovebox to pull back the carpet.
So 3 hours later you finally have access to the wires.
Total time to swap out the sensor for me 14 minutes. To plug it in 6 hours.
See pics below. You are looking at the driver side, without carpet. In the first pic I am pointing at the connection, with love.
Attached Thumbnails downstream oxygen sensor replacement-img_6638.jpg   downstream oxygen sensor replacement-img_6637.jpg
Old May 5, 2013 | 06:16 AM
bacardi11's Avatar
bacardi11
is this what a tech. must do to change that sensor. cut and splice new one in easier.
Old May 5, 2013 | 10:57 AM
ShawnOk's Avatar
ShawnOk
Was this driver side or passenger side downstream O2 sensor? This is a vid i found and had my tech use for passenger side once i purchased the part on my own...
Old May 5, 2013 | 04:17 PM
fj40ih8mud's Avatar
fj40ih8mud
NO, that is the upstream sensor.
Old May 5, 2013 | 04:29 PM
reelbb's Avatar
reelbb
I wonder how many 'book hours' that is?? It looks like more than I want to do on any given weekend
Old Aug 19, 2022 | 06:42 PM
GilfHunter's Avatar
GilfHunter
10th Gear
Unhappy Help needed
I got a short from the driver's side post cat O2 sensor which triggered the codes, P0100, C1201, and C1561. I replaced the O2 sensor and cleared the codes and they still appear. Any word on what the issue is?
Old Aug 19, 2022 | 11:19 PM
Raven01750's Avatar
Raven01750
See "2006 O2 Sensors Replaced" thread that you posted this question to. Please do not post the same question in multiple threads because it can really confuse things when you do that. Anyway. Good night.
Paul
StarGS3
Oct 19, 2017 06:06 PM
TheGs3
Apr 13, 2017 01:52 PM
dakeypoo
Jul 14, 2012 02:26 PM
chenxingha
RX - 1st Gen (1999-2003)
Jun 7, 2011 09:03 PM
