Flush Mount on OEM 18" SC430 Rims???
I am about to Install
SAGE 40mm Front RCA Kit
SAGE Rear 30mm RCA kit with Camber Correction adjustment using insert blocks
I plan on Buying & Installing
25mm Spacers Front
35mm Spacers Rear
This is going to be Installed with a Set Of 2006+ SC430 Rims.
I also planning on Repacing the Spring with (Tein or Eibach Pro Kit) which would Lower the Vehicle even Further. Do you for see any issue with this Set-Up??? Or can recommend a Set-Up that would give me a Flush Mount on OEM 18" SC430 Rims.
25mm Spacers Front
35mm Spacers Rear
Is this being done on your SC300 or is on a SC430?
I don't know anything about all the hardwares you got or your SC300, I can tell you I have 20mm/30mm spacers on my SC430 with stock wheels and the wheels are still pretty far from flush. I did a calculation once that indicate 45mm on the rears would make it flush.
I am not Big on Aftermarket Rims. I like the look of OEM Rims. I just don't like the Offset. Plus I had bad Luck with a Set of Aftermarket Rims a few years back with Pot Holes here in NYC. Hard earned money down the drain after Two months. A lesson learned
35 and 25 should work as it did on mine. Got for it.
I suggest that you check the torque whenever you do rotations. Just to make sure the spacer lungs are sitting right. That's what I do.
I saw a SC430 with GS350 19" F-sport rims, not sure about the offset thou.
It wasn't lowered so it did look like a SC430 4x4!!
similar to the wheels below.
http://www.ebay.com.au/itm/19-inch-A...item4d0239fa47
I might have a complete set of 25/35mm spacers for sale soon. Check out the pictures. PM me if you are interested. https://www.clublexus.com/forums/sc-...m-denmark.html
