power antenna.whats the trick,guys?
Old 07-06-12, 08:02 PM
lifethinkr
lifethinkr's Avatar
Default power antenna.whats the trick,guys?
ive been seraching but have found alot of different solutions.
my antenna mast is bent and im trying to remove it.
i got the nut off and i am having my wife turn the key on.
the antenna comes all the way out,but it seems to get stuck at the end of the cable.
i cant seem to get the cable to release so i can feed another one into the gear.
whats the trick to realeasing the entire cable? ithe cable is actually intact. but the mast is whats broken. anyway,just wondering what i need to do to get the cable to release from the motor.
thanks
Old 07-06-12, 09:14 PM
mdpuff
mdpuff's Avatar
You just need to pull harder and it will come out!
Good luck!
Old 07-06-12, 09:24 PM
VVTiBob
VVTiBob's Avatar
Search for the TSB in this forum...there are specific instructions (buttons on the radio to press) to eject the antenna
Old 07-06-12, 09:33 PM
VVTiBob
VVTiBob's Avatar
Heres the thread with the TSB...https://www.clublexus.com/forums/sc-...t-go-down.html
Old 07-06-12, 10:11 PM
stasis3131
stasis3131's Avatar
Not to thread jack but isn't there a shorter antenna you can buy that looks like a Honda s2000 antenna. I prefer the shorter look but can't seem to find on for this car
Old 07-07-12, 05:26 AM
lifethinkr
lifethinkr's Avatar
ok just read the tsb.i got one on order from fleabay.thanks alot everyone for your help.and jeers to MDPUFF for telling me to pull harder.thats exactly the wrong thing to do.
Old 07-07-12, 06:30 AM
VVTiBob
VVTiBob's Avatar
Just an FYI ..some of those who have ordered new masts from eBay vendors have regretted their decision and reported them here. ....the issue has been quality of the materials used to make the antenna. The thinner nylon breaks leading to more problems. Just an FYI.
Old 07-07-12, 06:56 AM
linus73
linus73's Avatar
i have replaced many power antennas, i have found that it is better to just replace the entire antenna assembly. i use only "harada antennas" they work well and are built well. and inexpensive as well, about $50- $65 depending on where you buy them.
Old 07-07-12, 08:14 AM
Harold57
Harold57's Avatar
Here's an older link with similar conclusions. Bob's TSB is the best advise since it comes from Lexus.
https://www.clublexus.com/forums/sc-...t-antenna.html
jasone36
06-11-17 12:15 PM
friarush
04-23-15 10:28 AM
bezee
01-22-05 10:47 PM
Lexson
SC- 1st Gen (1992-2000)
12
09-18-02 06:35 PM
Quick Reply: power antenna.whats the trick,guys?
