Does ML Amp Fan Always Run?
Old Jun 20, 2012 | 09:51 AM
jasone36's Avatar
jasone36
Default Does ML Amp Fan Always Run?
I am wondering if the ML amplifier amp fan always runs or only when it is needed. Now the that the weather is warmer I am starting to hear what I think is the ML amp fan from behind the rear sears run. I am not sure if this amp is always running or only when the system is on and when it's hot.
I typically use the cassette tape for audio input and even when I am not listening to anything I still let the "tape" spin... this probably keeps the ML amp turned on needlessly... now I am thinking this is probably a bad idea, it's probably best to turn off the entire system when I am not actively listening to anything. The only thing is I typically keep the audio system cover closed to hide the embarrassing tape deck from view and use the steering wheel controls for everything... but I don't know of a way to turn the audio system off from the steering wheel controls (without opening up the cover).
Just sharing some thoughts...
Old Jun 21, 2012 | 07:09 AM
Habious's Avatar
Habious
Press and hold the Mode button on the steering wheel. The stereo will beep, and shut off. A short press of the Mode button turns it back on.
ChuckB669
14
Mar 19, 2025 07:22 PM
Percy
26
Mar 27, 2021 06:06 PM
HandsomeB
Jun 14, 2016 07:09 PM
rmbb1981
Dec 21, 2014 05:35 PM
ser67
Aug 18, 2011 05:53 AM
