Window rubber trim part numbers?
Just scroll down a few rows, it will be in the far right column.
I have a 2002 with the same issue, but I haven't replaced the weather seals yet, tried putting duck tape around them but it didn't hold
LOL
https://www.clublexus.com/forums/sc-...d-noise-6.html
Replacment tutorial is in the earlier pages.
Hope that helps,
Harold
I'd recommend going ahead and lowering the window just a tad to where it just kisses the rubber otherwise the weatherstripping will rip probably within 6 months if it is really stretching it. Been there, done that. Adjust it to where the rubber is either just straightened out or barely stretched and it will last for a long time and have no noise. You can probably adjust each window in about 30 minutes or less.
Let us know how it goes,
Harold
Then pull the plastic coverings off of the adjustment bolts, place a piece of masking tape (or something similar) on the frame next to the bolts and mark where the middle of the bolts are (or one of the edges, whatever you are most comfortable with). Then make a second mark below that mark by the amount that you measured that you want to lower the window stop by.
Loosen the bolts, move them down to the new mark and tighten the bolts. (Be sure to move both, not just one.) Then try the window again. It may take a couple of tries to get it where you really want it to be.
It is at this point where you need to avoid the mistake I made and close the door as much as your set up will allow to verify that the window will indeed clear the door openning and is fairly level along the top.
After that, button it back up and check it out once more.
To answer your other questions, no, these two bolts only adjust how high the window will travel. They are both at the top where the fingers are pointing in that picture (post #72). They catch the bottom of the window when it is rising. The window ECU recognises that the window has reached its upper limit when that happens and turns off the motor.
https://www.clublexus.com/forums/sc-...d-noise-5.html
Hope that helps,
Harold
PS: let us know how it turns out.
But you've got the info now.
